Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2010, 12:47 PM   #1
HdRider04
CF Senior Member
HdRider04's Avatar
Default Power window ?
Drivers side window when going up it stops about 2" short and starts clicking.. Is it the motor or is it off track some how, down fine but stops 2" short of closing, It can be pulled up the last 2" but does not stay.
HdRider04 is offline   Reply With Quote
Old 02-25-2010, 03:28 PM   #2
wombvette
CF Senior Member
wombvette's Avatar
Quote:
The gears on the regulator are worn out. Common problem, every Corvette parts outlet has repair parts.
wombvette is offline   Reply With Quote
Old 02-26-2010, 07:21 PM   #3
DUB
CF Senior Member
Quote:
COMPLETELY!!!!!
Assuming that you are talking about a 1982 or earlier Corvette.
BUT...there is some possible "adjustments" to your NEW window regulator that may need to be made when you attach the motor to your new regulator...or you will have the same problem again...sooner than you think. These parts are stamped out and they can be off just enough so that the teeth on the motor gear...that mesh with the teeth on the regulator gear are not quite right. It is 50/50 shot on if it will be perfect or not...from what I have found. And I say this only because I have had new regulators...in the past, until I realized the problem ...wear out the teeth on a few months. It is easy to fix...but in my opinion do not ASSUME that the regulator is perfect just because it is new.
When you are in the door replacing the regulator or installing a new gear....there are other parts that you would want to check and replace. they are quite inexpensive but are very important in the window operation. Because nothing is worse than a sloppy window that has a mind of its own...and hard to adjust and hold that adjustment.
"DUB"
DUB is offline   Reply With Quote
Old 03-01-2010, 02:03 AM   #4
HdRider04
CF Senior Member
HdRider04's Avatar
Quote:
Originally Posted by DUB View Post
COMPLETELY!!!!!
"DUB"
It's an 86. does that make a difference? Thanks for the help
Old 03-01-2010, 02:57 AM   #5
wombvette
CF Senior Member
wombvette's Avatar
Well, yea, it would. 86 had a plastic tape gear. The plastic gear will break in cold weather. The regulator will need to be removed and the plastic rack replaced.
Old 03-01-2010, 06:40 PM   #6
DUB
CF Senior Member
And I have also seen an 86 Convertible have the steel type regulator in it. 86 seems to be a split year for some design changes...and I know for sure that the regulators are one of them.
"DUB"
Reload this Page Power window ?
Tags
2000, 2005, 86, adjustments, c3, corvette, fixing, forum, gear, passenger, power, problems, regulator, tape, window
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
