Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2010, 05:04 PM   #1
angelob
CF Member
Default Can you powder coat the drive shafts?
Can that be done without messing up the balance? Just courious.
Angelo
angelob is offline   Reply With Quote
Old 02-22-2010, 05:24 PM   #2
jrm747
Junior Member
im not sure about that one. i would imagine it wouldnt be that bad, as long as the shop did its best to apply the coating evenly. have you contacted any shops to see if they have ever done any? i have seen them painted before.
jrm747 is offline   Reply With Quote
Old 02-23-2010, 03:15 PM   #3
claysmoker
CF Senior Member
St. Jude Donor '09-'11
claysmoker's Avatar
I have two sets that are powdercoated. No problems as long as the applied powder is put on evenly.
claysmoker is offline   Reply With Quote
Old 02-23-2010, 04:39 PM   #4
hunterman
CF Senior Member
Id just find a good source to do it and it should be okay.
hunterman is offline   Reply With Quote
Old 02-23-2010, 06:39 PM   #5
DUB
CF Senior Member
Dents and excessive undercoating will throw off the balance of the half shafts and drive shaft. The drive shaft can be re-balanced. But the half shafts ( as I was told by my balancer guy) can not be balanced. True or not...I do not know. But I have used him for a LONG time...and he has never steered me wrong.
When the half shafts and or drive shaft is being powder coated. The main conern is making sure that the inner dimensions where the caps or "cups" of the universal joints get pressed into the half shafts and drive shaft stay PERFECTLY CLEAN and are protected from any powder coating getting in them. The caps or "cups" of the u-joint should fit in snugly without any side to side play that can be felt. IF you feel play in the caps or "cups"...that shaft should be replaced. And that goes for the outer rear universal joint flange that bolts to your inner rear bearing flange.
"DUB"
DUB is offline   Reply With Quote
Reload this Page Can you powder coat the drive shafts?
Tags
balance, coat, coating, drive, driveshaft, messing, paint, powder, powdercoat, shaft, shafts, withput
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
