Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-20-2010, 12:08 PM   #1
HotRodGirl
Junior Member
HotRodGirl's Avatar
Default Gel-coat
Was wondering if anyone can help by telling me what year GM started gel-coating the corvettes?
Your help would be greatly appreciated
HotRodGirl is offline   Reply With Quote
Old 02-20-2010, 03:06 PM   #2
porchdog
CF Senior Member
porchdog's Avatar
never . except for the first few prototypes in 53. to the best of my knowledge.
porchdog is offline   Reply With Quote
Old 02-20-2010, 05:35 PM   #3
jrm747
Junior Member
im not sure what years came with what, but i know that ecklers sells a gel coat for 53-72 year models. beyond that, i do not know if any came with it factory.
why?
jrm747 is offline   Reply With Quote
Old 02-20-2010, 06:04 PM   #4
porchdog
CF Senior Member
porchdog's Avatar
no gel coat on corvettes .
Old 02-21-2010, 10:37 AM   #5
DUB
CF Senior Member
Quote:
...except a few prototypes like "porchdog" mentioned
But one thing is for certain...the early body Corvettes and those which are NOT SMC...should be gel coated ( in many peoples opinion...mine included) OR...sealed with another product to aid in the issues with the porousity of the press molded fiberglass from the early years SMC does not require gel coating.
"DUB"
DUB is offline   Reply With Quote
Old 02-22-2010, 09:47 PM   #6
HotRodGirl
Junior Member
HotRodGirl's Avatar
Quote:
why?
Thank you
Hubby is helping someone with a restoration and the question came about. Figured if I came here I'd get the answer
Thanks for your time and quick response!
Old 02-22-2010, 10:39 PM   #7
wombvette
CF Senior Member
wombvette's Avatar
DUB and Porchdog,
There were a few more pieces over the years. Some of them were special low production pieces such as parts for the midyear big tanks, but at least one major example was in 1954. There was a run of bodies that were an experiment or engineering project that had the white gel-coat. On these cars most of the major body panels were gel-coated. Also, the `63 pilots cars had full gel-coated tubs and several body parts including the inner fenders. I agree that in general Corvette didn't have gel-coated bodies, but some specific ones did.
wombvette is online now   Reply With Quote
Old 02-24-2010, 08:40 PM   #8
whitey63
Junior Member
Was wondering what to use ,as my car sat outside for years and the glass is coming through in some areas and want to seal it up?Do I have to skim coat the body or is there a proper way to seal the glass.Thanks
whitey63 is offline   Reply With Quote
Old 02-25-2010, 08:13 PM   #9
DUB
CF Senior Member
Quote:
You need to specify the year.
"DUB"
Old 02-25-2010, 08:16 PM   #10
whitey63
Junior Member
Old 02-25-2010, 09:32 PM   #11
markids77
CF Senior Member
Either gel coat it or featherfill it or epoxy it to seal it up. All of these products have their proponents and all of the users have what I consider valid arguments as to why. I am certain you will get more, and more pointed, responses... get ready!
markids77 is offline   Reply With Quote
Old 03-23-2010, 12:16 PM   #12
vettesplus
CF Senior Member
vettesplus's Avatar
__________________
emkservices@comcast.net
"I would rather be judged by 12 than carried by 6, Go Fast but be Safe" (John Force)
vettesplus is offline   Reply With Quote
Old 03-23-2010, 08:38 PM   #13
DUB
CF Senior Member
1963
If you are not worried about NCRS judging....and are planning on painting it with the current basecoat/clearcoat systems out on the market....and not planning on painting it in lacquer.
I would gelcoat it...but that is just me.
Like earlier mentioned...you will find forum members that believe that their way is the best...due to possibly having a problem with a method that "back-fired" on them and cost them time and money to repair.
I am not writing that MY WAY is the best. But I have had issues with other methods and have found that the gelcoat has not never caused me any problems that have required a repair due to it failing.
Applying a polyester primer is a also acceptable...in my opinion...if for some reason you choose not to want to hassel with the application and sanding of gelcoat. Gelcoat and polyester primer are very close to each other in regards to the properties that they have in film build and curing. But in my opinion...gelcoat is the better of the two. As an example you have 93 octane gas..which is fine for many cars...but if you have a much higher than normal compression engine....it may require a much higher octane fuel to run at its best. Both are fuels that will work...but one fuel allows the higher compression engines to run better due to being much higher octane than what is considered normal. I hope that made sense...I read it a few times and hopefully I wrote it so it made sense.
Best of luck,
"DUB"
Old 03-23-2010, 09:21 PM   #14
whitey63
Junior Member
Thanks Dub,I appreciate the info,do you think I should look for a body shop that has experience with fiberglass? I really hate body work....
Old 03-24-2010, 07:04 PM   #15
DUB
CF Senior Member
whitey63,
I sent you a PM.
"DUB"
Old 04-02-2010, 04:14 AM   #16
joshwilson3
CF Senior Member
If Corvettes never had a gelcoat. Why do so many people talking about stripping a Vette down to the gelcoat? I know they even mention this on C4's.
joshwilson3 is offline   Reply With Quote
Old 04-02-2010, 04:57 AM   #17
lushdrunk
CF Senior Member
lushdrunk's Avatar
Ive done paint and body work for years and always assumed corvettes had a gel-coat like all other fiberglass. Like mentioned above, SMC fiberglass is of a higher quality then standard fiberglass and done not require a gel-coat, I could see GM getting away with just a primer/sealer.
But the older pure fiberglass cars it seems as if they would have to have some sort of gel-coat or gel-coat type coating to seal the fiberglass and cover/smooth the chopped fiberglass strands.
I know personally that the C4's have a black gel-coat type coating.
Ive sanded into it before and it is whats peeling from the door on my 94 vette. Ive actually got a chip in my hand I went and picked off just to see what it is and it looks like a normal, black gel-coat.
If they did not use a gel-coat then what did they use?
Josh and I where talking about this on another thread and it had me thinking. (smell something burning? )
Gel-coat in the can is heavy. Much more heavy then a typical primer/sealer type coating. Do you believe GM decided not to use gel-coat due to the weight? Or does it come down to a money issue.
(why spray a gel-coat and a primer when you can just spray a primer and save money on materials and labor)
lushdrunk is offline   Reply With Quote
Old 04-02-2010, 11:23 AM   #18
zwede
CF Senior Member
zwede's Avatar
Quote:
Except for very early cars (C1's), the Corvette panels were press molded which leaves a nice smooth surface. This surface is good enough to just require scuffing for adhesion before primer.
zwede is offline   Reply With Quote
Old 04-04-2010, 10:41 PM   #19
wombvette
CF Senior Member
wombvette's Avatar
Quote:
They are uninformed.
Old 04-04-2010, 10:44 PM   #20
wombvette
CF Senior Member
wombvette's Avatar
You might think that, but except for the few mentioned examples, Corvettes did not have gel-coat. The later SMCs have a black, epoxy or urethane type primer.
Reload this Page Gel-coat
Tags
body, c1, c3, c4, coat, coating, corvette, corvettes, corvetts, fiberglass, gel, gelcoat, panel, restoration, smc, spray
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
