Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-28-2010, 04:23 PM   #1
Old Yellow
CF Senior Member
Old Yellow's Avatar
Default Painting C6 headlight liner
I'm in the process of removing the clear outer lens on my headlights so that I can paint the inner liner black; as it appears in my avatar. That was done with photo-shop, and was a lot easier than actually doing them.
I want to use rattle cans to paint them, and would like to go with a satin finish black, rather than gloss or flat black.
My question is can anyone give me suggestions on the type of paint that will hold up best in that sealed environment. I'm thinking it might get hot inside the light from sun light passing through the clear lens, and I'm concerned about UV damage to the paint.
Would an epoxy be best or perhaps VHT paint?
I intend on giving them the rest of the winter to cure before re-sealing
the lights.
Any and all suggestions are appreciated.
Ed
Old Yellow is offline   Reply With Quote
Old 01-28-2010, 08:15 PM   #2
DUB
CF Senior Member
If you are going through all that trouble...why not paint it with good paint that had the flattening agent in it. Rattle can paint will work but it would take numerous coats so you get enough build to try to allow it to fight against the elements.
Remember ...rattle can paint has no hardener in it...much like lacquer of days gone past. And I am sure that you know what it trakes to keep lacquer looking good for a long time...especially if it is subjected to the UV's of the sun and heat.
IF you do not have proper spray equipment...just remember that some paint companies can mix up the paint ( less the hardener/reducer) and give you one of those aerosol fixtures that can screw onto a bottle and allow you to shoot the good paint by using an aerosol source.
Just a thought.
"DUB"
DUB is offline   Reply With Quote
Old 01-28-2010, 09:13 PM   #3
Old Yellow
CF Senior Member
Old Yellow's Avatar
Just a thought.
"DUB"
Thanks Dub, these are the kinds of ideas I'm looking for.
I would like to do it all myself and the aerosol fixture you mention sounds like a good idea. I've never heard of this type of device. Can you give me some more details on how they are set up.
I have a medium size compressor, (2hp) but I dont care to get into buying a spray gun for such a small project.
Ed
Old 01-29-2010, 06:44 PM   #4
DUB
CF Senior Member
Ed,
I have not used them...but I have seen them.
You will buy a set-up that for example would have a large glass baby food jar that would allow you to pour your paint mix into. Then the aerosol attachment would screw onto the jar. The propellant is in a canister that screws to the top of the jar and would be roughly the same size as the jar and the plastic feeder hose would be able to go into the jar with your paint.
Knowing that the aerosol is going to be at a set pressure to allow to pick up your paint mix and atomize it correctly....you may have to reduce/thin your paint mix just a bit more so you get the texture that you are looking for....because the correct mix ratio of the paint system you may use...may be too thick and not come out of the aerosol correctly....due to being at a lower air pressure than is normally required to spray the painit correctly....and the orifice of the nozzle is to small also. It should work but may take a bit of "dialing in".
Knowing that you have a compressor. There are paint guns out there that would work well and are really inexpensive. Because I do not know how much this aerosol attachment costs.
"DUB"
Old 01-29-2010, 07:05 PM   #5
Old Yellow
CF Senior Member
Old Yellow's Avatar
Thanks DUB
Ed
Reload this Page Painting C6 headlight liner
Tags
2005, 2009, aerosol, c6, cans, corvette, headlight, headlights, lacquer, lens, liner, paint, painter, painting, removal
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
