Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2010, 06:02 PM   #1
kaiserbud
CF Senior Member
kaiserbud's Avatar
Default Side Exhaust cover repairs - Epoxy instead of fiberglass???
If one were to use an epoxy to fix the insulators on side exhaust covers - what would be the best... for heat, stability... I just am thinking it would be easier to re-create some of the screw mounting areas without using fiberglass... ??? thanks
kaiserbud is offline   Reply With Quote
Old 01-17-2010, 07:24 PM   #2
DUB
CF Senior Member
Quote:
Most of the epoxy/uerthane adhesives I use require high heat applied to them and make them soft so they can be removed. SO I would check with an IR thermometer and see how hot it is in the area of your concern. I would feel that fiberglass resin and matt would do the trick...BUT...with the advances in epoxy/urethane adhesives, I am sure that there must be something out on the market that would do the trick. Looks like it may be time to call some of the major adhesive manufacturers. For me, I would do it in fiberglass and resin. Some of the adhesives I use are quite expensive. All depends on how bad off your insulators are.
Good luck,
"DUB"
DUB is offline   Reply With Quote
Old 01-18-2010, 08:22 PM   #3
kaiserbud
CF Senior Member
kaiserbud's Avatar
Thanks DUB... I am doing fiberglass tonight - so - using your thoughts and moving forward. You are right - fiberglass will work fine - has for 40 years
Old 01-19-2010, 02:06 AM   #4
kaiserbud
CF Senior Member
kaiserbud's Avatar
Got the insulators glassed up.... good taping helped a ton..... I used thin plastic to maintain separation of certain pieces - then when the resin set up, I gently pulled the thin plastic out....came out great.
I will grind out in a few days
Reload this Page Side Exhaust cover repairs - Epoxy instead of fiberglass???
Tags
corvette, covers, exhaust, painting
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
