Quote:
Originally Posted by JimmyS5600
Who is the manufactor of the enamal paint you picked up? Call or email them on what reducer to use. I have used both PPG and Dupont enamal paints and went with their reducer and hardner. Worked well.
Hope this helps.
Jimmy
Jimmy is corrrect...You will need to contact the manufacturer and USE their products so you do not run into an issue with incompatibility. I also would advise a hardener with the reducer.
Also ask for a Tech sheet...so you know how to mix and apply it.
I personally/professionally paint wheels with a basecoat....and then apply a scratch resistant clearcoat which helps in keeping them looking good for a long time...but...brake dust and residue can melt into the finish. Those wheels were powder coated...and it also can become damaged if your brakes are not up to par and you allow hot metal particles to get on them. I usually have them re-powder coated...unless it is a custom color I am looking for and there is no powder that matches it.
"DUB"
