Quote:
Originally Posted by zwede
It's really best to do this with the body on the frame, though. You can always lift it off again for paint.
. Preforming panel alignment when teh body is off...can POSSIBLY cause issues when trying to re-install these parts...after the body has been shimmed. Especially if you are trying to achieve GREAT lines and panel alignments.
Also I have found on many occasions that the aluminum rivets that are used to secure the metal reinforcement/hinge mounting plate to the inside of the door are often times loose and worn. This causes the door itself to have free-play in it eventhough the hinges are securely bolted to this mounting plate/reinforcement. I have to often remove and re-install these rivets....which are located at the front flat vertical area of the door where the hinges go into the door assembly....and would often times be painted body color. Not so much the ones that are located behind the interior door panel
"DUB"
