Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2009, 05:05 AM   #1
77TexVette
CF Senior Member
77TexVette's Avatar
Anyone use West Systems 105 epoxy system as body filler?
Hi everyone,
I have completed all the glassing and body mods I wanted using the West Systems 105 epoxy resin system and am just about ready to paint the whole car in SPI primer.
My default approach was to paint it in SPI epoxy primer, then complete the remaining body filler work where needed (shouldn't be much) and follow the paint steps outlined in the numerous posts here.
Question:
I want to complete as much body work as possible using epoxy system products. Why can't I just use the West Systems surface filling products like the 406 or 407 fillers with the same epoxy to complete my bodywork? I know it is harder to sand, but are there any other problems? It seems like this is exactly what is used for fairing on boats, etc.
http://www.westsystem.com/ss/product-selection-chart
So what I'd like to do is
(1) Use my trusty West System 105 epoxy resin/hardener, add in some West Systems thickening agent like the 407 filler or 406 filler and continue my body work with that (like smoothing out the transitions of the flares to the body, etc).
(2) Then primer it with SPI epoxy
My whole goal is to use as little "non-epoxy" (e.g. polyester body filler) products as possible. Let me know if you see any problems with this.
Thanks!
Michael
77TexVette is offline   Reply With Quote
Old 11-06-2009, 10:48 PM   #2
c4sailor
CF Senior Member
c4sailor's Avatar
Can't speak to using it n the car but that's all we use when fairinig keels on racing sailboats. The fillers, microbaloons, etc. I swear by West Systems Epoxy products for my race prep of the sailboat. I don't know if there would be any issues with priming over it. Probably a call to tech support at Gudgeon Bros (in Michigan) - makers of West Systems and/or the mfg'r of the primer would get an answer. Good luck.
c4sailor is offline   Reply With Quote
Old 11-07-2009, 08:50 AM   #3
porchdog
CF Senior Member
porchdog's Avatar
sounds like a plan to me. i'd use clear epoxy if it would buff
porchdog is offline   Reply With Quote
Old 11-09-2009, 02:36 AM   #4
gkz
CF Senior Member
gkz's Avatar
I'd stick w/407 for the filler; 406 is considered in the adhesive catagory. It's (407) not difficult to sand--80 grit is fine to cut it down. The more 407 that's added in the mix, the easier it is to sand, yet still maintains its strength. Stay away from the 410 filler. After fairing, give it a sealer coat of 105 resin/hardener. Scuff it before primer. I'm following the same process that you are. The above information I received from West Systems.
gkz is offline   Reply With Quote
Old 11-10-2009, 09:41 AM   #5
77TexVette
CF Senior Member
77TexVette's Avatar
Excellent. Thanks for all the replies. I know I'd never make any money as a professional bodyman, but this over-engineering habit must be in my german genes.
The first glass I laid down was with SMC epoxy from Eckler's, which worked very well and was a bit thicker than the West Systems epoxies.
However, nothig beats the convenience of having two containers of West Systems epoxy with their pumps attached - no measuring, no errors, no mess. I have been very happy with their products.
It is quite amazing how hard this stuff gets, but this is actually exactly what I want as a foundation. I will try to finish up the job in the next week and will post pics.
Michael.
Old 11-10-2009, 10:30 AM   #6
porchdog
CF Senior Member
porchdog's Avatar
west is a very good system . i don't think i ever heard of a failure with epoxy resin .i use it and build the surface with spi epoxy.
Reload this Page Anyone use West Systems 105 epoxy system as body filler?
Tags
105, 410, body, bodywork, corvette, epoxy, expoxy, filer, filler, microbaloons, resin, smc, stick, system, twxas, west
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
