Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-25-2009, 09:20 PM   #1
lilypad
Junior Member
Default questions i should ask
My 73 is close to being ready for paint. the car has been stripped and getting ready to sand.What is the best way to paint this car, so i can ask when i go and get some estimates. the color will be an original yellow.
lilypad is offline   Reply With Quote
Old 10-26-2009, 08:02 PM   #2
0grandmastercorvette
Former Vendor
I personally like the basecoat/clearcoat type of paint. Depending on the shop that you use...you may want to see if they are able to get that color mixed in basecoat. Then when you find a shop that will paint it for you...have them spray out a test panel...and have you approve the color...so you do not have any issues when you go to pick it up and the color is off.
Some paint companies may not have the ability to convert the older paint formulas to basecoat...seeing how basecoat came out AFTER your car was built. I have about 10,000 paint chips and if the formula to an older car is not available...I can surely find one that is so close it only takes a little bit of "tweaking" to get it right.
I am not a fan of "single stage" paint. It is good paint...but it does not have the clear to protect it...eventhough some single stage paints can have clear applied over it....but then your paint film can start becoming way to thick. Single stage paint...due to not ahving clear over it....can be stained...and possibly damage teh outer layer...so your paint has a defect. Much like a wood coffee table that does not have a layer of glass over it. If you spill your grape juice on the table...the juice is more likely to stain your wood....but if it had a glass top over it....the juice could not hurt what it cant touch. The clear coat provides protection against the UV's of the sun along with giving a layer of protection to the color coat...so MINOR scuffs can be buffed out of the clear ...as long as these scuffs did not make it through the clear to the basecoat color.
HOPE this helped.
"DUB"
grandmastercorvette is offline   Reply With Quote
Reload this Page questions i should ask
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
:lolg: Thougth I should share a little laughter with you guys. pk2401 C5 Z06 Discussion 9 04-21-2004 10:00 PM
Just bought a 73 coupe...anything I should know???? zog C3 Tech/Performance 23 03-15-2004 06:16 AM
Looks like I'm in need of a new motor..... 87 Ragtop C4 Tech/Performance 29 01-25-2004 09:40 PM
How can I get my 355 to scream up to 7000+rpm? '79ProwlerOrange Engine Mods 16 12-26-2003 09:23 PM
Is this what I should expect to see for the price? 96KICKS C3 Tech/Performance 17 11-08-2003 12:48 AM
Getting dyno'ed today, anything I should know? CarolinaC5 C5 Tech 20 01-17-2002 06:43 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
