Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2009, 07:24 PM   #1
Hornetpilot
Junior Member
Default Orange Peel in Epoxy
I put on two coats of SPI epoxy this afternoon. I was going to put on two coats of turbo 2K primer tomorrow, but I've got orange peel on a couple of panels. Should I block out the peel prior to the primer? If it needs to be sanded before the primer, what grit do you recommend?
Thanks again for all the help.
Hornetpilot is offline   Reply With Quote
Old 10-21-2009, 09:14 PM   #2
porchdog
CF Senior Member
porchdog's Avatar
not really. the epoxy is for sealing and adhesion . i would just continue with the turbo primer.
porchdog is offline   Reply With Quote
Old 10-21-2009, 09:18 PM   #3
ragtopman
CF Senior Member
St. Jude Donor '10-'11
ragtopman's Avatar
If you apply your 2k primer after the epoxy has gassed out, you will need to give the primer a 'tooth' to bond to the epoxy with and you can achive that by sanding and what grit all depends on your film build. If its a small build, I'd use 220g, a heavier build, 180g that way you dont ruin your epoxy or body work.
ragtopman is offline   Reply With Quote
Old 10-21-2009, 11:24 PM   #4
Hornetpilot
Junior Member
OK. Many thanks, fellas. I'll spray the primer tomorrow.
Old 10-22-2009, 08:40 AM   #5
porchdog
CF Senior Member
porchdog's Avatar
you have 7 days with spi to top coat or prime without sanding. ragtop's right. if you go past the window scuff with 180 .
Reload this Page Orange Peel in Epoxy
Tags
epoxy, orange, paint, peel, primer, spi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
flame orange jeaux C3 Tech/Performance 17 05-28-2011 12:55 PM
Time to paint the 85 Grzldvt C4 General Discussion 24 07-13-2002 12:14 AM
Thanks to DAVES80 I shot the primer and basecoat Rockn-Roll C3 Tech/Performance 9 05-08-2002 01:45 PM
Is Eckler's spray on gelcoat worth the trip or are the urethane primer/surfacers adequate? LemansBlue68 Factory Correct Resto 13 12-21-2001 12:58 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
