Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2009, 08:57 AM   #1
c66vet
CF Senior Member
Support Corvetteforum!
Default Gelcoat over Seams
I am using Eclkers gelcoat and want to cover the fender seams on the car. Can the gelcoat be sprayed over the seams or is there prep work required to the seams before coating with gelcoat.
2nd question - I have sanded a little too much on the firewall and have fiberglass fibers sticking out, especially around the rivets. Can I spray the gelcoat over the rivets or should all rivets be removed and then gelcoat the firewall. Some of the rivets appear to really stick out, someone suggested that I use bondo around the rivets to close the gap betwen the rivet and the firewall.
C66VET
c66vet is offline   Reply With Quote
Old 10-10-2009, 10:47 AM   #2
zwede
CF Senior Member
zwede's Avatar
I'd recommend grinding the seams out and fiber glassing them before gelcoat. The factory seam filler is weak and after all these years tends to turn to dust. If you gelcoat over it, there's really nothing backing the gelcoat.
As for the rivets: If they are visible you should drill them out, gel coat and then put new rivets in. Gelcoating over the rivits will look "cheap".
Edit: You should wait with putting the new rivets in until after you have it in primer. Then shoot some primer on the rivet heads before putting them in. This will give you the best look.
zwede is offline   Reply With Quote
Reload this Page Gelcoat over Seams
Tags
body, coat, corvette, gel, gelcoat, gellcoat, rivets
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
To gelcoat or not to gel coat 65RDSTR C1 & C2 Corvettes 24 05-25-2005 10:03 AM
Stripping, Painting, etc. 70 Vette venms96 C3 Tech/Performance 19 10-28-2004 08:39 AM
Removing Original Gelcoat....... sb69coupe Factory Correct Resto 12 09-08-2001 07:59 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
