Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-09-2009, 10:28 PM   #1
killer454
CF Senior Member
killer454's Avatar
Send a message via Yahoo to killer454
Default orange peel in paint
im painting my 1980 vett,first time i have painted a car.
my question is-is orange peel normal for a base coat/clear coat paint system?
my front clip cameout shiny but i have to wet sand to get it to look smooth.i did my door and now it looks very good but their is still little spec spots in it scattered throughout the door.do i have to keep sanding till the clear is perfectly smooth,what about these little spec spots from the orange peel.
i did not realize i would have to do this much wetsanding on this car to get that mirror finish.
thanks for the advice guys
killer454 is offline   Reply With Quote
Old 10-09-2009, 10:39 PM   #2
markids77
CF Senior Member
Some surface texture is normal for hand applied finishes. I can generally level the surface of my jobs using 1500 as a first color sanding followed by 2000, then polish. I used to paint professionally, not so for 25 years though. What grit is needed for you to level the surface? If more than 1000 grit is required please post photos taken from oblique angles to the paint so we can suggest gun adjustments to improve your surface finish. If you worry about "cut through", add an extra wet coat of clear; then there's more to sand/polish.
markids77 is offline   Reply With Quote
Old 10-09-2009, 10:40 PM   #3
markids77
CF Senior Member
And yes, you need to sand to uniform, dull flatness before polish to get a smooth mirror result. HTH!!!
Old 10-09-2009, 10:44 PM   #4
killer454
CF Senior Member
killer454's Avatar
well im starting with 1200 and then moving to 2500 for finishing it up.
then i use a 3m micropolish and then the 3m polisher.
i have one door done but if you put your face right up to the door you can see little specs scattered throughout the door.(i think i need to sand more on the door to get these out of it or is this normal and should just leave them in it?
Old 10-09-2009, 10:50 PM   #5
markids77
CF Senior Member
If you paid a shop to paint it you should expect perfection. Attaining perfection in your first respray might mean painting it a couple times before you are happy. If the tiny specs bother you, sand some more. If you cut through the clear you will see a "halo" effect after you polish... then you will need to degrease, resand, reclear and repeat as required. Is the finish nice enough to not drive you nuts looking at it? If yes you're done. If no, keep sanding!
Old 10-09-2009, 10:58 PM   #6
markids77
CF Senior Member
A good way to tell if you have sanded enough before polishing is to obtain a rubber squeegee from your paint supplier... they are sold as "spot putty" application squeegees. After you think it's flat, run water over the area then squeegee it clean with the applicator. In good light any imperfections left in the surface will "glow"... be shiny in appearance. A smooth area with no imperfections will appear uniformly dull. Then you know it's cut flat and ready for the next grit or polish.
Old 10-09-2009, 11:02 PM   #7
killer454
CF Senior Member
killer454's Avatar
markids thanks for the advice
and im going to sand some more these spec are driving me crazy right now this is my first paint job and i want it perfect.
thanks for the help i have read your post and understand them completly and now i know what i need to do.
thanks for the advice on my first paint job
Old 10-09-2009, 11:11 PM   #8
markids77
CF Senior Member
It is a lot of work, but when you have it right you will be proud to say you did it yourself. Be patient. Expect a mistake or two. Learn, redo and press on... then go out and get "best paint" awards at the next cruise night, or concourse!
Reload this Page orange peel in paint
Tags
clear, coat, corvette, inpaint, job, orange, orangepeel, orangepeelinpaint, paint, peal, peel, pictures, surface
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Orange peel in factory paint? David426 C5 Tech 15 11-29-2004 02:46 AM
C6 Orange Peel pic Alex1217 C6 Corvette General Discussion 22 09-29-2004 12:45 AM
The cause of Orange Peel is as follows jimman C6 Corvette General Discussion 66 09-18-2004 12:07 AM
Orange Peel CAPN17 C5 General 11 07-20-2004 12:20 AM
No more orange peel? yeagerda C6 Corvette General Discussion 18 04-02-2004 12:46 AM
Zaino Negatives Roadfrog Car Care Discussion 48 08-11-2003 01:04 AM
Orange Peel with the C6 Paint? Doughan C6 Corvette General Discussion 56 08-01-2003 09:57 PM
What's with the orange peel? Highroller C5 Z06 Discussion 11 02-26-2003 07:22 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
