Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-30-2009, 08:38 AM   #1
spaceboyjohnny
Junior Member
Default getting oil out of fibreglass
Hi all, i have a client with an unfortunate problem. When his car was transported to aust in a container, it appears that the car on top has leaked transmission fluid onto the removable hardtop. The top was painted and in poor contition, thus fluid has soaked into the glass thru the paint crazing. The area is quite large, about 18'' diameter.
how do we fix this one? As much as i hate to soak fibreglass with any fluid i feel this may be the only way... either hot soapy water, solvents, something! probably have to repeat and dry out many times?
or is it basket case?
any idea's greatly appreciated
thanks all
spaceboyjohnny is offline   Reply With Quote
Old 09-30-2009, 09:14 AM   #2
zwede
CF Senior Member
zwede's Avatar
Would "aust" be Australia? If so that's good, summer's coming. Put it outside in the heat to bake. Keep wiping the oil off. Yes, it will take a while.
Porchdog will slap me, but I'd use thinner to wipe. I think he has some other product he likes that works also.
zwede is online now   Reply With Quote
Old 09-30-2009, 09:24 AM   #3
porchdog
CF Senior Member
porchdog's Avatar
bake in the sun and use simple green or dawn soap once a day until gone . ppg dx330 wax and grease remover after that . 330 is "first clean" so it is pretty harsh. do not use it first though or you will dissolve the fluid and drive it further into the class.
porchdog is offline   Reply With Quote
Old 10-01-2009, 12:54 AM   #4
spaceboyjohnny
Junior Member
thankyou both for the invaluable suggestions... yes, its in australia and i plan to use the sun to its full advantage!
cheers
Darryll
Old 10-01-2009, 07:49 PM   #5
0grandmastercorvette
Former Vendor
When your hardtop is outside...flip it upside down...and the ATF will come to the top surface ...where it can be wiped off with chemicals. This allows gravity to help in this issue...causing the fluid to go down...which will make it appear on the top surface of the hardtop.
I just had to do a hood on a 1970 with a major oil spot in it...due to an oil breather puking oil on the underside for along time and the owner not keeping up with "things". I turned the hood upside down...and applied a heat lamp on the engine side of the hood... and got the oil to flow to the top surface..(which was facing towards the ground) and wiped it off...and did this for about a week and got the oil stain to go away. If you can remove the headliner...this may help in allowing the sun to get to the fiberglass and really heat things up.
Maybe this will help you also...if other ideas do not fix it.
"DUB"
grandmastercorvette is offline   Reply With Quote
Reload this Page getting oil out of fibreglass
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intake! Dealer! Paint! Bronco's! Ahhh!!!!!!!!!! smack123 C4 General Discussion 16 12-18-2004 06:48 PM
That POR-15 paint is unreal! 67HEAVEN Factory Correct Resto 16 08-08-2002 02:50 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
