Quote:
Originally Posted by Kubs
I assume the epoxy resin takes place of the fiberglass resin? Can I use fiberglass mat or is there an SMC mat I should use? Is there a better name brand I should use over another?
Kubs,
Yes you can use fiberglass mat.
I use WEST SYSTEMS epoxy resin and hardener...which should be easy to find up in Cleveland. WEST MARINE down here sells it..and it is what I use for this type of repair and also use it doing carbon fiber repair on nitro funny car bodies. GOOD STUFF.
I saw the photo's you posted and it would be in your best interest that you modify the hood scoop before you plan on laminating it to the hood. The gaps are quite wide and will make it hard to get a air free lamination. I personally would grind where Icould and add on to the scoop with polyester resin and mat to get the scoop to fit tighter....so when I went to laminate the scoop to the hood ...the seam would be tight.
I guess that there is NO flange on the bottom edge of this scoop....right? If ther were..you could bond the scoop to the hood and then cut back that bonding adhesive and then apply your epoxy resin and matt.
Just try not to cut an opening in the hood alrger than what youo actually need....for strength reasons...so your scoop doesn't crack in the future. You will also might consider taking good care when opening and closing the hood when completed. Don't slam it down...but that is up to you. Your hood has alot of flex in it right now...before any cutting and modifying...and with this flex..it could cause for cracks if you are not careful with it.
"DUB"
