Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-17-2009, 11:25 AM   #1
zwede
CF Senior Member
zwede's Avatar
Default Cut & Buff 70-72 Egg-crate grills?
My '71 is finally getting painted and I'm doing some of the cut & buff myself. The painter will do all the cut & buff on areas where he can use his polisher and I'll do the parts where his machine doesn't work.
The egg crate grills are pieces I'm doing. These were the roughest parts of the car due to flaking chrome that I had to sand blast off. Plenty of pits in the pot metal.
I'm doing them all body color, no chrome edges.
I shot them with K36 2K primer, and blocked to 400. Then the painter painted them red with 3 coats of clear (PPG 2021 concept clear).
Wondering what is usually done to cut and buff these? I have put many hours into the first side and it is coming out good, but I'm having to do all of it by hand. I probably have a good 8 hours in it...
Are there any machines that can do the intricate shapes of the grill and get into the corners?
My process is:
2000 grit paper taped to a paint stick, sand everything flat (this goes quick).
PowerCut compund rubbed by hand (this is the step that takes forever).
PowerFinish glaze followed by FinishGlaze rubbed by hand (this goes fairly quick).
Any way to speed up the compound step? A machine would knock it out in 1/10 the time, I just don't know of a machine that can do it?
zwede is online now   Reply With Quote
Old 09-17-2009, 11:53 AM   #2
porchdog
CF Senior Member
porchdog's Avatar
sand to 3000 and it will go easier.
porchdog is offline   Reply With Quote
Old 09-17-2009, 12:00 PM   #3
zwede
CF Senior Member
zwede's Avatar
Thanks. Would a scuffpad do the same or would it be too coarse? 3000 grit is only available at autopaint stores. The closest is a 1 hour round trip so if a scuffpad does the trick it would be good. But if not I'll go get the 3000 grit.
Old 09-17-2009, 12:28 PM   #4
porchdog
CF Senior Member
porchdog's Avatar
urethanes dont buff too well by hand. see if your painter has some 3000 pads you can buy. by the box they are a little pricey. i would have sanded them smooth and flow coated them so i did not need to buff. too much work for me.
Old 09-17-2009, 01:17 PM   #5
zwede
CF Senior Member
zwede's Avatar
Quote:
I can definitely see the advantage of doing that.
Old 09-17-2009, 08:23 PM   #6
0grandmastercorvette
Former Vendor
If you watersand them smooth and re-clear...the clear will lay down smoother and flatter and often times keep you from having to sand and buff them. I just did a 1970 in Cortez Silver...and that is what I did. The car is slick as glass (due to being sanded and buffed) and the eggcrates are just as slick and smooth.
Just a thought.
"DUB"
grandmastercorvette is offline   Reply With Quote
Old 09-18-2009, 10:42 PM   #7
zwede
CF Senior Member
zwede's Avatar
Update: I had some small primer spots after the cut & buff on the grills. Considering the poor shape they were in before paint I wasn't too surprised. I took them back to the painter and he'll touch up the red and then re-clear. I think that will take care of it. Thanks for your advice Porchdog & Dub.
Old 09-19-2009, 09:02 AM   #8
jnb5101
CF Senior Member
jnb5101's Avatar
seek out a local dental laboratory. they will have polishing rag wheels that are designed for getting into small areas. they're good for the grills and headlight bezels.
jnb5101 is offline   Reply With Quote
Old 09-19-2009, 10:17 AM   #9
porchdog
CF Senior Member
porchdog's Avatar
looks great guy. now the fun part starts.............. buff buff buff
dang , wrong thread but same fella
Reload this Page Cut & Buff 70-72 Egg-crate grills?
Tags
70, corvette, grills
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
