Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Paint/Body
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Paint/Body Corvette Materials, Techniques, and How To
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-17-2009, 06:01 AM   #1
demonx
CF Senior Member
demonx's Avatar
Default For those that paint their jams etc first
When you paint your door jams etc first, then install the door and paint the rest, how do you not get tape lines?
I'm assuming that when you do this theres some precautions to take at that cross over point?
demonx is offline   Reply With Quote
Old 09-17-2009, 01:00 PM   #2
KEG64
CF Senior Member
KEG64's Avatar
3M has a transition tape for this purpose. I have never used it so I can't say how well it works, but it is what was recommended for my needs.
http://solutions.3m.com/wps/portal/3...beS07L5SX2K0gl
KEG64 is online now   Reply With Quote
Old 09-17-2009, 08:20 PM   #3
0grandmastercorvette
Former Vendor
To remove any worries about tape lines...I personally clearcoat the car in a dis-assembled state. What year model are you talking about? Each c-series can be done different ways. A C-2 is different than a C-4. Would like to know...so I can try to answer your question. Taping is a very precise process and when removing it after clearing the basecoat often times needs to be done almost immediately...so the clear will lay down flat and not dry with a sharp edge. there are tricks...but need to know your year model.
"DUB"
grandmastercorvette is offline   Reply With Quote
Old 09-18-2009, 02:31 AM   #4
demonx
CF Senior Member
demonx's Avatar
1970 vert.
__________________
Old 10-27-2009, 12:05 PM   #5
M_T_0
CF Senior Member
paint the doors off the car, paint the rest of the car with the doors off then install the doors. if you have graphics that span the doors do the above then paint the graphics then remove the doors and clear over all parts then reinstall the doors.
M_T_0 is offline   Reply With Quote
Old 10-27-2009, 07:57 PM   #6
Former Vendor
Quote:
totally and partially.
The only added advice I can offer is that...because you never mentioned what color your are choosing. That if you are using a solid color...the above procedure is CORRECT.
BUT if you are using a metallic/pearl...it would be wise to apply several coats with everything dis-assembled...then BEFORE the final coat...install the doors, set the hood in place along with the convertible deck hatch....and other items set close to where they belong (wiper door and grille, fuel door, wiper door trim, etc.) So when you blow the final coat on...you know that all of the metallics/pearl will be correct and even. Then CAREFULLY remove these items...unless you are applying graphic designs with tape and such...and if that is done...then you remove these panels and clear the car.
One last bit of advice...at the paint store they should have what they call a "spray out card". It is a piece of paper with white and black squares on it. It is used so when you paint your car...you paint it the EXACT same way..NO DOUBLE OR TRIPLE COATING IT....so when you have enough paint on it...you can not see the squares...thus letting you know that you have "COMPLETE HIDING" of your basecoat color.
Many of todays metallic/pearl colors do not cover well...and this "spray out card" is a LIFESAVER. SO when you pull your car out of the booth and have car headlights shining against the side of your car...you do not see any undercoat showing through. Which can happen...and has happened. I have repaired many cars due to this issue...because due to the intense headlight beam...are not like the lights in the booth...which is different type of light... along with the shadows that many booths have....due to lighting.
"DUB"
Old 11-03-2009, 07:41 PM   #7
M_T_0
CF Senior Member
yep treat the metalic and pearls the same as graphics
Old 11-04-2009, 12:28 AM   #8
demonx
CF Senior Member
demonx's Avatar
Thanks for the replies.
No metallic. Solid red.
Old 11-05-2009, 06:53 PM   #9
Former Vendor
Post #5 is correct for a solid color. You should have no problems ....depending on how fast your red covers completely to "total hiding".
"DUB"
Old 11-06-2009, 03:46 PM   #10
63vette_dreamin
CF Senior Member
63vette_dreamin's Avatar
Hint: Use a green sealer when spraying reds,will cover in 2-3 coats at the most.
and seal the whole panal if possible.
63vette_dreamin is offline   Reply With Quote
Old 11-06-2009, 07:19 PM   #11
porchdog
CF Senior Member
porchdog's Avatar
i use white under reds. you will get true color.
porchdog is offline   Reply With Quote
Old 11-07-2009, 07:01 PM   #12
63vette_dreamin
CF Senior Member
Default Color 101
Quote:
Try it out sometime on a test panal.Red will cancel out the green and cover faster.Coverd is coverd,wont affect color. I was a color matcher at a color lab for a major paint mfr for over ten years .
Old 11-08-2009, 09:51 AM   #13
porchdog
CF Senior Member
porchdog's Avatar
don't think i could handle that. green is my bad color, everybody has a favorite color and one they hate. i just never liked green. i paint everything in pieces and some times months apart. red over white always matches well. i've seen all the little test panels with checkerboards on them but i still prefer white for my base.
don't envy you that job. matching color will drive you nuts sometimes.
Old 11-08-2009, 11:22 AM   #14
ragtopman
CF Senior Member
St. Jude Donor '10-'11
ragtopman's Avatar
And if your a DuPont guy, they use/used a value shade for sealers and they want you to use basically a white sealer on reds(value shade 2-3).
ragtopman is offline   Reply With Quote
Old 11-08-2009, 06:19 PM   #15
Former Vendor
Knowing that many of US know this....but this is for those who do not know.
I personally do not have a favorite color for sealer....so to speak. It ALL depends on the color. If the color is full of high solid pigments...then usually it will cover very quick....and it doesn't matter. If the color has alot of weak or transparent pigments or alot of pearl in it...that is when I break out the white/black checkerboard color evaluation cards and do a spray out to make sure I am getting to complete hiding. Sometimes I tint my sealer, sometimes I shoot a solid color close to the final color...but whatever I do...I make sure that the entire car is completly covered in ONE COLOR. NO spotted colors on the car before painting. Like shooting solid yellow....you better paint it white first or you will regret it.
And when it comes to color matching...which I know more than a thing or two about. It often depends on what the factory used and re-painting it the same way. I have shot on enough cars that were "see-through" when headlights were shining on a panel...like a door...where you can actually see the undercoat showing through the color. and if it were painted correctly...it WOULD NOT match.
So basically...different processes for different situations. It is NOT "cut and dry".
"DUB"
Reload this Page For those that paint their jams etc first
Tags
car, door, jams, painting, tape
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
things to look for when buying a c4 lange C4 General Discussion 19 08-06-2005 02:29 PM
corvette c4 as my first car BKLYN_VETTE C4 General Discussion 57 07-28-2005 11:33 PM
C4 Buyer's Tips FFCus C4 General Discussion 19 07-03-2005 01:46 AM
A few questions from a Vette Noob. mydartswinger C4 General Discussion 11 07-01-2005 02:06 PM
Buying your first vette here is the checklist Redeasysport C4 General Discussion 14 06-21-2005 09:29 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
