Paint Jobs
It's all in the prep! The best paint in the world will look like crap if your bodywork in not correct. I spent just over $10,000 which included body work, parts, and paint job. I took mine to someone who specialized in Corvette's so it just depends on what you want and how much you are willing to pay for the best.
[ image was here ]
[ image was here ]
Modern paints are catalyzed. In my shop, the last car of the day was left in the paint booth overnight. It was always the best looking. Too much heat can cause solvent pops, and can dull the final finish. Use the proper reducer for the temperature and let it sit overnight.
Members, 85dave is correct, low temp ovens (150 to 175 degrees ) only help evaporate the solvents used during painting, however the new catalized paints including the clearcoats are way better than what was used years ago. As for the paintjob on the C-3 it is gorgeous. I only wish I could see it close up to enjoy it. I started painting in 1955 out of high school and I am sure glad I dont't have to do it any more as it is a tough way to make a living. Man, I sure wish I could rub my hand over that Met. green C-3 It would make an old car painters day. Allentown Ernie.
Baking Paint
Baking a Paint Job only makes the paint set up faster against letting it air dry few days. It does not make it any harder nor does it make it a better paint job. What you may find out by baking it is any pin holes or bad body work that the car may have. When pin holes in the fibre glass are present under baking the air will expand and cause a blister in the paint. I would have the body work done by someone that understands how a fibreglass car should be prepared for paint. After the repaires are done and the car is in final primer I would park the car in the sun to see if and bubbles or air blisters appear in the primer, repair those reprime and sand and paint. I work as a sales rep for a paint manufacture and have been painting for a few years. 30 +
64muscl
PS Take your car to a shop that knows Corvettes. Pay now or pay again later.
64muscl
I'm looking at a car that has the paint stripped and is ready for a new coat. I was wondering how much you guys paid for a paint job and how much I should expect to pay. I don't want a show quality job, just something that shines when I wax it and cruise. Also, there is a shop in town that bakes the paint on. Is there an advantage to a "baked on" paint job? Thanks for any help and suggestions.
-Shark Mann
-Shark Mann
-Shark Mann
-Shark Mann
As far as I have been told, baking a car is an expensive and commercial operation. It simply accellerates the dry time for commercial painters to have the car ready in one day. It also ages faster on the car. Think slow.
Do it yourself paint jobs will run 2000.00 for tools, materials and home modifications!
