FS: Complete A&A setup with all supporting mods BNIB
I have a full setup here I’m planning to get started installing this winter. But I may want to go another direction with this car and I use this money. I got excited and went on a spending bender. But may have got ahead of myself which I tend to do sometimes even though I said I wouldn’t this time on this car.
If someone local was looking to have a pretty much down to the smallest part setup ready to go without all the leg work I’d be inclined to let it all go and save the local some money. This was setup for a dry sump car using the stock radiator. I have a little over 10,500 including the tires into the parts.
Would let it all go for $9700 or $9000 without the tires not really looking to split it up as that’s too much work. Everything is BNIB. If not I’ll just roll on and leave car at some safer hp levels and try to keep the SBE happy. Lol
A&A Black v3 T-trim/3.8 pulley
dsx aux fuel system
dsx flex fuel kit
Fix 1000cc injectors
monster lt1-sk clutch kit/slave/billet bearing/speed bleeder
MM wild can dry sump 10an
aem x wideband/boost gauges
A pillar pod
Zeitronix ethanol content gauge
Oil cooler block off plate kit
Spare belt and plugs
Zr1 map sensor
355/30/19 kuhmo ecsta v720 acr
Located in Federal way, Washington .
dsx aux fuel system
dsx flex fuel kit
A pillar pod
Zr1 map sensor
