Humount installed with single DIN stereo
Bought this from an outfit in Canada that does these for ALL sorts of cars, and it is the LAST thing to finish off my interior LED install It looks in person! It is machined out of Delrin, and has an aluminum faceplate that is detachable by use of screws in the corners. The CD player sits in a slot between the faceplate and the bracket assembly (which the head unit's cage is installed), making it sit more flush with the dash as if it were a factory item. The aluminum tape is to cover the wave guide around the LED's, so they don't project light in your dash to be seen from all the joints. I'm very happy with it, and the light is quite uniform, a little bright, but I will fix that when I do an all out stereo install later (I'll hook it up to the factory dimmer since my head unit doesn't use it). It's hard to find good pics of this install, so I took some of my own
