Videos from Turn 2 May 4th
Thanks Tom for putting on a fantastic event as always.
My first time ever burning through a full set of pads in a day AND boiling my brake fluid It was pretty scary not having brakes and doing over 100 coming to a corner.
Not sure if I caught anyone on the forum in these but I have a number of them with plenty of vettes
DISCLAIMER: I was hyper sensitive / frustrated due to the red MR2 and the Green Mini that were not letting people by most of the day so anything I said out of frustration in any of these videos was really just a result of that.
After watching the video I realized the red Z06 probably had an instructor and wasn't aware of the fact that I was behind him.
For any of you that haven't been to one of Tom's events, I highly encourage you to come out. You won't find a better group to run with.
On to the videos:
Mike (#505): *Thanks for throwing rubber at my windshield Mike :p
Red C5 Z06 and Silver C5 Coupe
Having some fun after Tom opened the track up to everyone:
On to the videos:
Sr.Random input generator
Have you synced the data with Dashware at all? There is a sync feature you can use to make sync perfect. However, if you're not using an external GPS receiver with higher frequency (like the 10 Hz Q-Star I use), the data will be coming from the 1 Hz GPS sensor your phone has, which will delay and skew your Dashware gauges at times.
As for GPS, it's a Contour2+ camera with GPS built in (so not my phone).
Yep, there is a sync section, where you can offset the data file so it would match video with no lag (or vice versa).
Nice post, Austin. Looks like you were having a ton of fun.
I'll be out there later this summer once I get new hand controls for my car that are a bit "safer" than my current setup.
Thanks for posting the videos.
