Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Pacific Northwest
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Pacific Northwest Idaho | Oregon | Washington | Hawaii | Alaska.
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2009, 07:41 PM   #1
moorashj
Junior Member
Default car cover - yes or no?
Mixed thoughts about this and need some advice. I live in washington. Have a 78 pace car and will be keeping it in the garage for winter. Will run it from time to time to keep her going. Don't want to put it up for the winter, at least not now. My quesiton is: My wife got me a very nice cover for it with the flannel-ish material on the inside. I was told that i should not use it since moisture will collect under car and possible cause rust. I should keep cover off, put up hood and let the moisture go. So, it is better in the area with rain should i cover the car or keep it uncovered. Thanks
Jason
moorashj is offline   Reply With Quote
Old 11-02-2009, 08:58 PM   #2
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
If your garage is sealed fairly well from the weather especially around the garage door, a cover should not be a problem. The cover will keep dust off the finish and still allow air to pass thru the cover. Some folks even place lightweight stuff on th ecar for additional storage area. If you don't have pets that get into the garage, put some mice bait under the car or by each wheel.
If you intend to run the car on occasion, the cover has to come off anyway so it's a good time to inspect the interior for any moisture. You can some moisture-absorbing bags in the various catalogs and keep one in each footwell and 1 or 2 in the back.
Don't forget to run the A/C for 10 minutes or so each time you start the car. That will keep the seals and o-rings from cracking.
c4cruiser is offline   Reply With Quote
Old 11-02-2009, 09:00 PM   #3
last901
CF Senior Member
last901's Avatar
Location: Never be seen driving something you can actually afford.
Despite the special nature of your Corvette, me thinks you worry too much.
I have found the flannel-lined car covers to be excellent at keeping the car pretty much dust-free during storage. (I presume this is one of those realtively thin tan covers) It even works well, occasionally, for those times when you need to park outside overnight and don't like to wake up to a lot of dew on your car. Still, they are not waterproof. The downside of the flannel covers is they tend to leave a lot of lint on fabric convertible tops. Easily resolved.
Provided your garage floor is concrete and not bare earth, I wouldn't expect rust from storage to be a problem. Even if it wasn't concrete or asphalt, I don't expect you to have any issues. If the garage is attached to the house, it will probably ameliorate any serious collection of moisture.
I would advise you to not use the car cover if the car is not clean, especially if you use the cover outside. For example, if you take it on a tour and run into some rain or dust, I wouldn't put the cover on the car unless you clean it first. Even that is open to debate.
Oh, and if you do decide to take the cover with you on overnight trips or even evening outings where the car will be parked out of sight, think about a cable and a small padlock to secure the cover. I've had mine stolen once.
last901 is offline   Reply With Quote
Old 11-02-2009, 11:53 PM   #4
Iroczlover
CF Senior Member
Iroczlover's Avatar
Send a message via MSN to Iroczlover Send a message via Yahoo to Iroczlover
if its out side FORGET the cover, in the wind & what have you we get it will scratch your paint.
If its in side go for it.
Iroczlover is offline   Reply With Quote
Old 11-03-2009, 02:47 PM   #5
Lead Foot 66
CF Senior Member
Lead Foot 66's Avatar
I have put my car in hibernation about ten days ago.
I use an indoor car cover mostly to keep the dust/ crud off it while is sits in the garage.
My prep is easy:
1) Gas stabilizer in a full tank of gas,
2) Tires pumped to ~ 40 lbs.,
3) Exhaust pipes covered by a baggies with a rubber band around them
4) Battery Tender hooked up,
5) Dryer sheet in little aluminum foil pans in driver's/passenger's floor mat.
That's it.
Lead Foot 66 is online now   Reply With Quote
Old 11-03-2009, 03:44 PM   #6
DidntSettle
CF Senior Member
DidntSettle's Avatar
Location: Manchester - Political correctness is tyranny with manners.
What a travesty to have to put your Corvette in hibernation for the winter. Mine works all year round, as does Mr. Peabody's.
DidntSettle is offline   Reply With Quote
Old 11-03-2009, 05:36 PM   #7
moorashj
Junior Member
Default thanks all
Well, at this point the garage is pretty well sealed for the winter. I will most likely put the cover on it so it does not get dusty and will start it at least monthly to inspect it and keep it running.
Has anyone ever put a dehumidifier in their garage around here?
Old 11-03-2009, 05:44 PM   #8
alexmadison
Junior Member
IF you get a car cover make sure it's breathable (yes, it can be waterproof and still breathable) I ended up going with a waterproof breathable cover from Empire Car Covers
I was going to go with cover king, but it looks like the same cover, but $100 bucks cheaper.
http://empirecovers-review.blogspot.com/
alexmadison is offline   Reply With Quote
Old 11-03-2009, 07:14 PM   #9
WETVET
CF Senior Member
WETVET's Avatar
Send a message via Skype™ to WETVET
My prep is easy:
That's it.
Another item most over look is to place 1/2" plywood pieces (4) a bit larger than the foot print size of the tire. Place these under each tire to keep an insulation barrier from the concrete floor and the tire.
just my .02
WETVET is offline   Reply With Quote
Old 11-04-2009, 07:36 AM   #10
884fun
CF Senior Member
884fun's Avatar
Quote:
Mine doesn't melt when touched by water either.
__________________
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.
884fun is offline   Reply With Quote
Old 11-10-2009, 04:40 PM   #11
Herringchoker
CF Senior Member
Herringchoker's Avatar
Location: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Quote:
Drive it!
Herringchoker is offline   Reply With Quote
Old 11-10-2009, 05:15 PM   #12
Richard EVO
CF Senior Member
Richard EVO's Avatar
I don't like car covers. Unless your car is 100% clean everytime you put the cover on, dirt on the car will transfer to the cover. Then the next time you put the same cover on the clean car, the dirt will transfer back to the car. There's no way to avoid this unless your car is squeaky clean everytime you put the cover on.
Richard EVO is offline   Reply With Quote
Old 11-10-2009, 05:49 PM   #13
YNOT2K
CF Senior Member
YNOT2K's Avatar
Quote:
YNOT2K is offline   Reply With Quote
Old 11-10-2009, 11:31 PM   #14
Maui
CF Senior Member
St. Jude Donor '08
Maui's Avatar
Send a message via AIM to Maui
I always covered mine in the garage because there is a lot of dust floating around and because I smoke cigars in the garage. I didn't want the cigar smell to permeate the car.
Maui is offline   Reply With Quote
Old 11-11-2009, 12:18 AM   #15
Bu La'ia
CF Senior Member
Bu La'ia's Avatar
Default no cover here
I have never had to worry about this. My vette isn't a garage queen, it does not live to enter shows, it longs for the road.
However, you should do what you feel is best for you to sleep at night. Some like chrome, some like painted, some red, some black...
Just enjoy.
Bu La'ia is offline   Reply With Quote
Old 11-30-2009, 06:01 PM   #16
alexmadison
Junior Member
Old 03-31-2010, 06:58 PM   #17
cc8074369
Junior Member
+1 for empirecovers, mine is much better than I expected for the price, great fit.
cc8074369 is offline   Reply With Quote
Old 04-02-2010, 02:04 AM   #18
BlueSteel
CF Senior Member
BlueSteel's Avatar
Send a message via ICQ to BlueSteel Send a message via AIM to BlueSteel Send a message via Yahoo to BlueSteel
All that is necessary is a California Car Duster and some quik detailer to keep a car squeeky clean. After a road trip I dust off the Vette wipe it down with quik detailer then on goes the cover. There has not been any scratches caused by the cover.
BlueSteel is offline   Reply With Quote
Old 04-02-2010, 03:47 PM   #19
Rock'n Blue 08
CF Senior Member
Rock'n Blue 08's Avatar
Best cover is from the fabric shop. They have soft flannel.
That you can get in any length and in wide widths.
I just cover them up to keep the dust off.
A dealer sent me a free cover. I sent the piece of crap back.
Who in there right mind would put that POS on there car?
Rock'n Blue 08 is offline   Reply With Quote
Old 04-08-2010, 03:30 PM   #20
cc8074369
Junior Member
What's it made out of?
even if it's indoors the material still needs to be breathable or you can get moisture damage.
Reload this Page car cover - yes or no?
Tags
2005, car, clean, corvette, cover, covers, empirecovers, flannel, forums, huge, ot, overnights, storing, tan, wall
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Might be the best upgrade to my car YET! Well minus the motors... ski_dwn_it C4 Tech/Performance 35 01-30-2004 09:17 AM
Ahhh, yes...BLUE DEVIL!!! Butta C6 Corvette General Discussion 39 12-20-2003 10:56 PM
F/S Cover, Hurst Shifter, Mats & More CINISTR C5 Parts for Sale/Wanted 15 09-20-2003 07:25 AM
Z06 or Stinger Exhaust GoF4st C5 Tech 33 02-26-2003 01:43 PM
HEY 89Vette re:Valve cover fitting (moderate size images) -=Jeff=- C4 Tech/Performance 14 09-20-2002 02:17 PM
Going Too Fast + No Active Handling + Poor Road= CRASH (Very Long post + Big Pics) Grzldvt Southern California 31 04-22-2002 06:53 PM
CAR JUST PAINTED--They screwed it up--NEED PROFESSIONAL ADVICE QUICK Randy 71 C3 Tech/Performance 53 03-18-2002 10:28 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
