My VIR garage mate - I don’t understand why GM won’t make a car like this…
So in the primary market they are virtually unobtanium, just like the Porsche you pictured.
Btw, the C8Z has faster lap times than the GT3, and virtually identical lap times to the GT3RS. So stop the whining.
Just mod your car to your liking.
They DO make one. It's called the Z06 GT3.R. It's sold by GM. I filled out an interest form to buy it as a "collector/enthusiast" but was not called upon for purchase.
The Porsche pictured in thread starter RapidC84B's first post is a 991.2 GT3 RS. It has some obvious alterations to the stock configuration: the brakes have been modified (PCCB brake rotors and calipers have been removed), a rear wing with goose-neck struts replaces the stock 991.2 GT3RS rear wing, and canards have been added to the front bumper cover. The wheels are not original to the car, and it's safe to assume that the wheel and tire selection is part of the car's owner's intention to adjust the car's balance of performance specifically for the track.
The price of a stock 991.2 GT3 RS easily undercuts the price of a 992 GT3 RS in today's ADM market: https://finder.porsche.com/us/en-US/...&order=closest.
The Empire State Region of the FCA regularly has cars like the C8 Z06 and 991.2 GT3 RS at its events at Watkins Glen International and Lime Rock Park. Those cars have reliable, sustainable performance and run competitive laps--especially in the hands of skilled drivers.
My main point being is if you want a GT3RS, then get a GT3RS or wait and see what Chevy is going to do with the Zora, they may go all out like a GT3RS. Again though, good luck getting one. One could put tens of thousands into a C8 Z06 and still have 1/4 million left over for track time, consumables, repairs etc vs a newish 992 GT3RS. Just food for thought in this discussion.
I’ve had a Porsche with carbon buckets and they are wonderful when in them and on the track. They really get annoying quick if you are trying to use the car for anything else. I’ll take the compromise with Z06 seats over those every time. Unless you are buying them as just a dedicated track car, which even most GT3RS owners don’t do.
https://www.cars.com/vehicledetail/d...-697c36a43ffc/
Going on a C8 Z06 forum to tell EVERYBODY how much better your modified GT3 is and that GM "pretends" to make a track car is a weird flex. It smells alot like "I'm the smartest guy in the room" syndrome.
One of Corvette's biggest positive and negative is that it's a GM product. They get the breadth of engineering, volume, cost savings, etc. but are also hampered in some ways by that big corporate leviathan (side note, for instance why is every GM product tied together via design language? You see similar themes from a Cadillac flagship to Corvette to the trucks to econo EV's. Each division should have its own unique language.) The Corvette crew is unique with their passion and expertise but they have to work within the machine to get a good, high value car to the people.
I was recently thinking how Chevy should make a Z06.R by adding the huge ZR1 aero/bonnet, strip out as much weight as possible and include some genuinely great lightweight bucket seats.
I like my comp seats. If you pull the belt all the way out it locks. I do this with my seat back and then use the seat memory button to return to the normal setting. Doing this you can make the belt as tight as you want, and I find that it holds me in quite well. I did look into a harness bar so I could use a harness, but you could only do a 4 point, and PCA (who I frequently run with) requires at least a 5 point. I don’t see why GM couldn’t add slots for an anti submarine belt in their “comp” seats.
GM is very leery about doing anything to "promote" harness use due to legal, but then again they have the harness shoulder pass-throughs in the seats so why not a sub strap slot too? There was a Q&A at one of the Bash events when C8 was first coming out and they were asked about incorporating shoulder belt mounting into the factory chassis/bulk-head behind the seat and they said Legal wouldn't let them get into that at all.
I am not sure if the Comp seats are one piece. On my GT2 seats, you can slide the sub strap up between the bottom of the seat back and the back of the seat cushion and sit on it, having a true 6-point harness with functional sub strap.
The 3" competition lap belt, put on tight and then moving the seat forward a small amount does compress the seat bottom and gain you a little more head room (1/2" to 1"?). I find there is more head room in the C8Z than my C6Z had.
#33
The TeamTech Jet Pilot harness is an excellent one and does not need a separate sub strap or mount as it is integrated with the 3" lap belt. $$$ but excellent.
