GMC truck wipers
St. Jude Donor '08
GMC truck wipers
Have a 2007 GMC 1500. Wipers will not work once the motor gets hot. Found this out several weeks ago while on the Interstate. Went thru a heavy downpour with wipers working fine. Rain let up and I turned the wipers off. Got into another heavy rain and turned the wiper switch and nothing. Able to get to an exit and pull into a station. Needless to say no more wipers. Had to cautiously drive home. Just wondering if others have had this problem. First time this has happened. Thanks,
Gene
Gene
Do you have a heated windshield wiper system on your 2007-2009 GM full-size pickup? If so, it’s likely part of a wide-ranging recall of 1.36 million vehicles including 18 different models of Buick, Cadillac, Chevrolet, GMC, Hummer and Saturn cars, trucks and SUVs.
Gene
Gene
St. Jude Donor '08
Don't have a heated system. There is a recall to replace the wiper motor cover, but according to GMC my VIN is not part of the recall. Truck is pretty much useless if rain is forecast. My son-in-law will check all of this next week. Truck is like new. Bought it 1 1/2 years ago with low mileage. Presently has 42,000 miles on the odometer.
Gene
Gene
The heated windshield washer fluid recall was a separate issue where the system could catch fire. The recall forced GM to disconnect the system and give owners $100 which to me wasn't worth it since I loved that system. 07 was a bad year for GM with the first year of the new trucks, they had a lot of gremlins.
Just rainX the thing and drive it till you can fix it
When my dad was still alive both of his last Trucks had problems with the wipers he had to pay to have fixed at the Chevy dealer.
A 96 Silverado and a 99 Tahoe (still the old body style in 99). If I remember right it was the gear box on those that ended up going bad.
After he had the Tahoe fixed GM issued a recall on the wipers and sent him a check to reimburse the amount he paid to have them fixed.
I just figure it was one of those things you expect to bad like the Vortec Trucks fuel pumps.
St. Jude Donor '08
Thanks to all for the info. Info found by my son-in law referred to the cover needing to be replaced. Will look this up on You Tube as mentioned above. My first thoughts were to use Rain-X and see what happens in the next downpour.
Gene
Gene
