Laguna Seca record
#301
I can tell you from my limited track experience in my Previous C5 Z06 and current C6 Z06 that having to modify your driving style to make up for a car's shortcoming would be a major PITA.
It requires the utmost concertinon on faster tracks like Buttonwillow and Willow Springs the last thing you want to do is be worried about changing your driving to overcome the cars shortcomings. The Z06 power train should be built robust enough to exceed pretty much any Amateur track enthusiasts track day.
#302
For those who say the new ACR is track only. A friend just did a 5,000+ mile road trip in an ACR.
#303
I would have preferred they kept the front splitter on to see if it survives on the road. If it didn't, than the ACR should have tracked without the front splitter.
In my book it's not ok to test the car in one trim on the road and in another on the track. The Z was only .1 second slower, which I'm sure would have gone to no difference without a front splitter.
#304
George well said. I'm also a big Z06 fan , and wanted to trade in my 2010 Z06 for a new one, but GM needs to fix the cooling issues on these cars. All the new Z06's I have seen at the track. Have had an issues. From the power steering overheating, to having to short shift it 5k RPMs to keep the temps stable,and I know some of these guys. They are real good drivers . I saw SBC and a Stick on my last track day. Talked to him a very nice guy. He has also contributed a lot on this forum IMO. Contributed on the cooling issues on the car, and he took a lot of flak here from it. His car ran good, but after a few laps you can see the car losing power and getting slower. While a cammed bolton C6Z06 was right behind him lap after lap. It doesn't even get hot here..
#305
And yet, the Road and Track mag had to disassemble the front splitter to drive it around town, and reassemble to drive it on track.
#306
Yep, stage 3, even the wicker is up all the way. Cup 2s as well. Nearly 13,000 miles now.
Oh, and I live in San Francisco. Quite possibly the hardest city on sports cars.
#307
#308
By your reasoning, the same alignment should be used on both the street and the track, if the same aero bits have to be used on both the street and the track.
PS- GM says not to use the Z07 tall "winglets" and the clear center "wickerbill" on the street, implying that they should only be used on the track.
#309
The removable part is the splitter extension, not the entire splitter. The extension doesn't reduce ground clearance any. But, it does increase the front overhang, which would make it a little more difficult to enter steep drives with. The extension is also a wear item, designed to be replaced when worn. The splitter shown on the red ACR in the snow, is always on the car. Ground clearance meets NHTSA safety requirements, just like the Z07 splitter does.
Then you have a problem with GM using a special alignment for the track and another alignment for the street, on the Corvette?
I'm not sure why GM says to use them on track only. The winglets make the car a bit harder to park in the garage but no big deal.
#310
This is about as dumb as saying that the Z07 and ACR can't use their sticky factory tires, if someone gets a nail in one. The tire didn't survive the drive, right?
#311
V10LEE
My 2010 ACR Viper I can drive it hard get good lap times, and never have to worry about nothing. Just making sure I have enough gas for the next session that is all. It's such a great car . My new ACR wow I can't imagine how much better it os compared to the one I have been tracking. Especially after seeing Darius taking his out on Laguna Seca..
I hope GM fixes everything on the 2017 Z06. If they do I will definitely be buying one, and will be excited to track that too..
#312
Your logic here is ridiculous. Ever seen a ZR1 splitter get crunched? I did it twice on my previous Corvette. One was a huge dip, the other a tire tread in the road. Should those cars run without the splitter, too? I've also had the winglets on my CTS-V take a beating and crack. Again, should they run without them? Because of road damage? You think C7 Z06 splitters are immune to road damage?
#313
R&T removed portions of the front splitter for road testing. To me that indicates they feared breaking it on the street. I haven't seen anyone remove the Z06 splitter for street testing. Nor have I heard any magazine break it. That to me it means something, to you maybe nothing.
ZR1 what? I don't care, not part of the comparison.
You are grasping at straws here. The size of the front splitter matters. It's not a 1,0 (broken, not broken).
Sounds like GM is finally waking up, and going in the right direction now. This is good to know. I hope the 2017 Z06s will have this on the cars from the factory. No more cooling issues, limp mode , having to have to short shift it , power steering giving out, and so on.It should of never been like this when they released the new Z.
#314
I was in SF last month and the roads seemed quite nice. Chicago, Detroit and NYC are far worse.
There will always be people who will run the full aero bits on the street, even though it's not what the manufacture intended. But putting the add-on aero bits at the track is no different than adjusting the suspension, changing tire pressure or pulling all the extra crap (coffee mugs, spare tire, trash, tools, etc) out of the car in the parking lot.
#315
Must need a lot of downforce for sitting in traffic.
Adding and taking off aero is important because it is in ADDITION to "adjusting the suspension, changing tire pressure or pulling all the extra crap (coffee mugs, spare tire, trash, tools, etc) out of the car in the parking lot."
Aside from the time need it will wear out from mounting and dismounting.
You will also need some space in the trunk to carry all that aero.
There is already tons of prep to do at the track even with a car that's bring and run like the Z.
OK, big point to make here is that when you see an ACR on the road it may not be able to run the same setup it does at the track. So what a Viper does at the track is more different than what the Viper can do on the road. Another way to put it, the Z's performance can be stretched on a wider array of pavement, whereas the ACR requires you to drive you splitter and toolbox with you to adapt.
#316
More like I'm not bothered by the extra downforce so I feel no need to adjust it all the time.
Regarding the splitter extension and diffuser add on blades, even without them mounted, the ACR will still be a better handling car than 99.9% of any production car in the world, especially on the street.
Until you get over 80 mph, those added aero pieces are just in the way. I just don't know of any curvy road in NorCal that I could consistently drive between 80 mph and 130 mph (common road course speeds) and not be a major danger to other motorists or on the radar of the local LEO. A lot of people that drag race their Gen 4 ACR's actually remove the rear wing since it has so much aero drag, even on the 1/4 mile drag strip. My point is, unless you are a major hot shoe around the track, you could never install the splitter extension and diffuser blades and be just as fast (or slow as in my case, lol). Aero is a fantastic thing on the track (pretty useless at sane street speeds) but very few of us will be able to fully harness the aero capabilities of the Gen 5 ACR Extreme. It really is at another level.
I see putting on the aero for the track no different than GM's recommendation to run 15-50 Mobil 1, less antifreeze, adding brake cooler rings, adjusting the alignment to more aggressive numbers, adjusting the Z06's wickerbill, different brake fluid, etc.
It really is a good time to be a gearhead....even a mildly prepped C7 with a manual will destroy just about anything on the track short of an ACR or Z06 in the hands of a good driver. I do have a feeling that by next spring you'll see GM counter with something to give Vette loyalists a weapon against the GT350R, Viper and Porsche GT3. I'm thinking something along the lines of a Corvette TDS (Track Day Special).
#317
How does it feel knowing that your car is slower than an ACR on a track and a standard Viper on the street?
#318
As far the Z06 being "slower than a standard Viper on the street", both cars are pretty evenly matched, I would say it's a driver's race honestly. The Viper (and even the ZR1) have a better top end compared to the C7Z, especially one with stage 2 or 3 aero.
Personally, I wouldn't mind owning either of the two cars as both are awesome American super cars. Like the poster above you said (or somewhat said), these cars will pretty much destroy anything out there besides the "elite super/hyper cars" for under $150k. It's a good time to be and auto enthusiast!
#319
Good to see you're in SF, I'm assuming your home track would either be Sonoma or Thunderhill. I just picked up a C5 Z06 as my new primary track car....I'm sure we'll meet up as soon as it dries out. It might end up being a long wet winter (hopefully, lol).
Moving to ACR rubber on the next set of wheels. After looking at the track times done so far, I think the car will be within a second of the ACR on any of our tracks while running the same Kumhos. That is the car. Me + the car? I think I'll always be faster in the Z06 Z07. It's softer sprung and the car in general should be easier to exploit at the limit. All of that and I can arrive and drive.
Show me one guy that changes all his track settings and fluids back to street on the Z. With track settings on street the car doesn't behave much differently. I don't notice any difference driving it either. My tires wear out in the center blocks first. I'll give you one thing, the cooling rings on the Stingray are a ridiculous thing. However, I think the Stingray guys use them on the road as well. If you track enough you'll change those rotors out often enough that it doesn't matter.
Now, if anyone with an ACR would like to try to make it in my driveway with the whole extreme ACR aero I'd like to see it. A stock VW Golf scrapes, and I still have my front lip after some 300 drives over it.
I honestly don't care that the ACR is faster. What I really care is that all Vipers can run 20 minutes on the track in just about any conditions. I'm an enthusiast at heart and hold no grudges to other drivers or manufacturers that build high performance manual cars, and the Viper is my backup plan, just not the ACR.
#320
But you'll sit here and complain that life isn't fair, that the ACR got to use all the parts it was designed to work with. LOL
