hard starting car
hard starting car
I think I have an idea of what this is but want to double check as I don't want to have to replace it in case I'm wrong...
It has been VERY VERY hot lately 100+ degrees in my garage. When I go to start my car it turns over then dies.
I prime the fuel line / pressure by turning ignition on and off several times w/o going to start (motor off). Then going to start it kicks right over and runs fine. Or if I give it gas when turning it over it starts up.
My guess is (1) fuel map is wrong for temperature - my hope or (2) fuel pump is going out.
I'm going to run a bunch of fuel cleaner through it. Then replace the fuel filter. If that doesn't do it I'm guessing it's either the pump or the pressure regulator.
Any other suggestions before I empty my wallet into the car again lol
FYI. It's a 1998 buick century. I just love the car too much to get rid of it. Great car about 100k on pump. 80k on motor. 170k on car.
I would check the Throttle Position Sensor it might not be reading right.
They are easy to check with a volt meter, you don't need anything fancy just a 5 buck one from harbor fright.
You should be able to find the test procedure for your car online.
You're both lifesavers I will have to pickup those tools at harbor freight and scan my car at the parts store.
I have done the throttle position sensor check on other cars. It's pretty straight forward, I hadn't thought of it though. Thanks!!
I didn't think to check stuff upstream of the pump in the system - suppose that's why they call me a backyard mechanic lol
It's actually working perfectly now though. It was approaching 110 degrees outside when it was hard to start. I'm kind of wondering if that wasn't part of the problem.
Now it's more survivable weather.
