Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Livernois/RHS 429ci Stroker for 2006 CTS-V
Old 07-11-2012, 01:53 PM
0Livernois Motorsports
Supporting Tuner
Livernois Motorsports's Avatar
Default Livernois/RHS 429ci Stroker for 2006 CTS-V
An out of state customer sent his 2006 CTS-V to us for a long list of modifications.
We are currently building the new engine which is based of off an RHS aluminum block. This will be a N/A 429ci build
Parts consist of:
Livernois Forged Steel Stroker Crankshaft
Livernois Exclusive 11:1 compression Forged Pistons w/ Fully Coated Top and Skirts
Livernois Exclusive Rings, Locks, and Wrist Pins
Livernois Spec H-Beam Rods w/ ARP 2000 Bolts
Livernois CNC LSX-LS7 Cylinder Heads
Livernois Stage 2R Max Camshaft
Comp Short Travel Race Hydraulic Roller Lifters
Coated Bearings
ARP Studs
Melling Oil Pump
Here are some photos minus intake and covers
We will also be installing:
Kooks Longtube Headers
Kooks Midpipe w/ Cats
Corsa Exhaust
CAI
LS9 Clutch
Aluminum Flywheel
Shifter
Coil Overs
Sway Bars
Toe Rods
Trailing Arms
9" Differential
35-Spline Axles
Thanks for looking!
Regards,
Rick LeBlanc
Livernois Motorsports is offline
Old 07-11-2012, 01:59 PM
USMCFRC
USMCFRC's Avatar
Very impressive build sheet. So why the RHS block and not a LS7/2 block?
USMCFRC is offline
Old 07-11-2012, 02:23 PM
Supporting Tuner
Thank you!
Normally for this level of build, we would, but the customer specified he wanted an RHS block and 6-Bolt heads.
-Rick
Old 07-11-2012, 04:04 PM
vigalante
vigalante's Avatar
Originally Posted by LivernoisMotorsports
Thank you!
-Rick
You have a ballpark estimate what a little motor like that costs???
vigalante is offline
Old 07-11-2012, 04:09 PM
Supporting Tuner
Fully assembled oil pan to intake would be roughly $20,000
Thank you,
Rick
Old 07-11-2012, 07:19 PM
vigalante
vigalante's Avatar
Thank you,
Rick
How much HP and torque does that baby produce? Very decent price from looking around.
Old 07-12-2012, 09:31 AM
Supporting Tuner
I'm not sure. He's not using a very aggressive camshaft. Specs are 235/242 .603/.618 114 LSA.
We have several C6Z N/A stock bottom end head/cam, bolt-on builds that make 600-630 RWHP with our stage 3 camshaft, but it's more aggressive than he wants in this car.
Thank you,
Rick
Old 07-12-2012, 10:51 AM
vigalante
vigalante's Avatar
Thank you,
Rick
Nice to see a N/A Chevy engine, that will be used as a grocery getter produce close to 600HP and still be user friendly!
To Livernois/RHS 429ci Stroker for 2006 CTS-V
Quick Reply: Livernois/RHS 429ci Stroker for 2006 CTS-V
