Corvette Forum
Go Back   Corvette Forum > Off Topic > Other Cars
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-08-2009, 05:08 PM   #1
ZBrink
CF Senior Member
St. Jude Donor '06
ZBrink's Avatar
Send a message via AIM to ZBrink
Default Oil Consumption Occuring...Is a Change of Viscosity in Order?
Okay this is in regards to the 5.3 L in my 2000 Yukon with 160k. I'm posting it here because there is a greater amount of knowledgeable people on this forum when compared to any other I am a member of!!
I've owned this Yukon since 130k, have used only Mobil 1 - 10W30 and it consumes about a quart or a little less in between every change interval of 6k. It seems to "run" fine. I have no idea what oil the previous owner used or what change interval he had setup.
Anyway to cut down on consumption? Is this bad??
ZBrink is offline   Reply With Quote
Old 11-08-2009, 05:27 PM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
1 qt in 6k miles is not bad.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 11-08-2009, 10:59 PM   #3
Shortimer
CF Senior Member
Support Corvetteforum!
Shortimer's Avatar
Considering your high mileage, one quart is normal. Short of a re-build with new rings and valve guides, seals and so on, I'd just keeping adding the oil. Before you go to a thicker oil, check the owner's manual to be sure you can go to a thicker oil. Consider the outside air temps as well during the life of the oil before the next oil change. A thinner oil (5-30W) is often used as a Winter oil. Newer engines require thinner oils. Hope this helps.
Shortimer is offline   Reply With Quote
Old 11-08-2009, 11:28 PM   #4
BSheppard
CF Senior Member
I also have a 5.3 in my Z71 that uses a little oil. I bought it with 40k on it back in 2003. It is a 2000 model that now has 180k miles on it. I was using 10w30 Mobile one and it was using about 1/2 quart between oil changes (5000 mile oil changes). After switching to 15w50 Mobile one, nothing has changed. Still using about 1/2 quart each change. I live in the south and it never gets all that cold so I think I will just stick to the heaver oil in it from now on. It never smokes even on start up so I'm not sure where it is going either.
BSheppard is offline   Reply With Quote
Old 11-11-2009, 04:45 PM   #5
Dave68
CF Senior Member
Dave68's Avatar
Location: Member: Double Yellow Dirt Bags San Diego, CA
You can try this if using conventional oil in a high mileage engine:
https://www.mobiloil.com/USA-English...ge_10W-30.aspx
Dave68 is offline   Reply With Quote
Reload this Page Oil Consumption Occuring...Is a Change of Viscosity in Order?
Tags
consumption, oil, oilconsumptionviscosity, viscocity
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
