Corvette Forum
Go Back   Corvette Forum > Off Topic > Other Cars
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 10-28-2009, 07:24 PM   #1
Nick McCardle
CF Member
Nick McCardle's Avatar
Send a message via AIM to Nick McCardle
Default '87 Buick Turbo-T Limited, 32k Miles- GA
Price is listed at the bottom of the post below the pics.
Make: Buick
Model: Regal Limited, Turbo-T : 1 of 1,035 produced.
Mileage: Right around the 32,500 mark...I still drive it on nice days.
Exterior: White and Chrome
Interior: Burgandy with Bench Seat/Column Shift
Options include power windows, power locks, concert sound, tilt, cruise.
Re-built PowerMaster added from Advance Auto back in April of this year.
Modifications....
Parts with ** were bought new and put on less than 500 miles ago/the work was done less than 500 miles ago.
All other parts are also very low mileage, most less than a few thousand.
**Spectre Air Filter, ATR SS Crossflow Exhaust, High-Flow Catalytic Converter
QBoost In-Car Boost Controller, Terry Houston 3” Downpipe, 3” Cut-Out
Full Throttle Speed 4” MAF Pipe & **MAF Translator
Limit Engineering GT70 P-Trim Turbo w/ HD Actuator
**TR Custom Parts Super Extreme Front Mount Intercooler (27x17x3” core)
**Razor’s Alcohol Injection Kit
**Flow Matched Delphi/Lucas 79lb Injectors
Walbro 340 Fuel Pump w/ Casper’s Hotwire Kit
**Kirban Billet Adjustable Fuel Pressure Regulator
Bilstein Shocks, **Rear Air Bag Kit, Kirban Driveshaft Loop
Large Rear Pinion Snubber, Centerline Convo-Pro Wheels
**Kirban Soft Compound Rear Brake Shoes
275/50/15 Mickey Thompson ET Drag Radials
ScanMaster 2.1, ORiS Boost Gauge, Casper’s Cam Tool, **TurboTweak Emissions Chip
Under-Hood Fuel Pressure Gauge, **TurboTweak 79lb Injector Alcohol Chip
**Innovate LC-1 Wideband w/ DB Gauge and LogWorks Software
VDO Water Temperature, Voltage, & Oil Pressure Gauges
**Stock Heads – Machine work done by Proline Racing
Competition Valve Job
Gasket Match Intake Ports
T&D 1.55 Ratio Roller Rockers
Manley Severe Duty Intake Valves – 1.775”
Manley Severe Duty Exhaust Valves – 1.500”
Shortened Valve Guides, Pep Viton Seals
PAC Beehive Springs, RJC Bullet-Proof Head Gasket Kit
**Kirban Torque Strap , Valve Cover Breathers, RJC Biggie Oil Filter Adapter
Hypertech 160 Degree Thermostat, **TR Custom Parts Aluminum Radiator
Earl Brown Modified GM Timing Cover
**Full Throttle Speed 210/215 Revolution X Roller Cam Kit
- Comp Roller Lifters
- DLS Adjustable Cam Stop
- Chrome Moly .080 Wall Pushrods
- Austemper Comp Grind Camshaft
RJC Power Plate
Home Ported Stock Throttle Body, Home Ported Stock Intake/Plenum
Lightened and Balanced Rotating Assembly, TRW Forged Pistons, std/std crank
**Imperial Transmission Cooler
**Vigilante 9 ½ Non-L/U Billet Converter – 3400 Stall
**Neal Racing Transmissions Built Non-L/U BRF Transmission
- Extra Clutches, Sonnax Wide Band, Hardened Stator, Hardened Sun Gear,
Art Carr Hardened Forward Drum, .570 and .400 Boost Valves
The car has a clear title and registration, the car was re-vinned by the state of GA many years ago due to being a theft recovery and has salvage history which causes a mileage conflict on CarFax as a result. The car was not damaged, smashed, or parted. I have zero doubt in my mind the listed mileage is correct and you won't either after seeing it. The car does NOT have a salvage or rebuilt title or anything of the sort. The title is free and clear with no issues.
Car is tuned well enough to run on the new set-up, but pig rich and not nearly as well as it could be. However, well enough to walk a bolt-on LS1 T/A from a slow roll by about 6 cars easily . Everything is there to do it, I just haven't. You can log with the wideband and LogWorks software and adjust fuel and timing through the MAF Translator and even more so on the chip through the ScanMaster. WideBand is completely installed minus the calibration switch, something that won't take more than 30 minutes or so..but I'm not sure if I'd want to mount the switch or not so I'll let the next owner decide.
Here are pics taken 10/26/2009 showing the condition of the car.
Click the thumbnail for a larger version.
More pics on next post.
___________________________________
I'm asking 17.5k. However, I understand the economy and car market and am open to offers...
I'm motivated to sell it and need the money, so don't hold back if you're interested.
I'd prefer not to trade. However, I would consider cash + trade for my car...but, like I said- I need money so the more cash the better.
I'm looking to downgrade as far as a weekend car goes and would prefer something valued at 5-7k or less + cash.
Please send e-mail in place of PM if interested, it's hard for me to check all the boards I have the car on often. Thanks!
Nick.McCardle@gmail.com
Nick McCardle is offline
Old 10-28-2009, 07:25 PM   #2
Nick McCardle
CF Member
Here are five of my favorite pics of the past couple years.
Old 10-28-2009, 07:56 PM   #3
IMXCITD
CF Senior Member
Support Corvetteforum!
IMXCITD's Avatar
sweet!
IMXCITD is offline
Old 10-30-2009, 01:48 AM   #4
vvv90
CF Senior Member
vvv90's Avatar
This is seriously the nicest example of a regal, let alone, GN I've EVER seen.
OMG! What a great car for the money!
Good luck with your sale! I wish I was in the market for a cheap muscle car because there's nothing out there nicer!
God da#m
vvv90 is offline
Old 10-30-2009, 01:51 AM   #5
Nick McCardle
CF Member
Thanks for the comments!
I'm open to offers, trades of all kinds, etc if anyone's interested.
Old 11-01-2009, 08:11 PM   #6
Nick McCardle
CF Member
Was a super nice day out today so I took it out for some cruising. Put about 100 miles on it with everything from back roads to traffic to highway driving. Car did great and performed with no issues.
Still for sale or trade, taking offers.
Old 11-03-2009, 02:21 PM   #7
Nick McCardle
CF Member
Oh well, car is now on eBay. Has a reserve, but a good bit lower than the listed price in this thread.
eBay Item 180428046141
Old 11-03-2009, 03:08 PM   #8
RUGBY
CF Senior Member
RUGBY's Avatar
What a cool car!
RUGBY is offline
Old 11-03-2009, 11:11 PM   #9
Closer_2001
CF Senior Member
Closer_2001's Avatar
Owned 2 GNs over the years...gotta love the Limiteds!!
Closer_2001 is offline
Old 11-10-2009, 03:41 PM   #10
Nick McCardle
CF Member
Car did not sell. Not so good for me, but good for you as I'm relisting it.
The starting price is $1.00 and the reserve price is much lower than the last listing.
Auction starts at 9:45pm EST tonight, November, 10.
Auction ends at 9:45pm EST Friday, November 13.
Auction Link below, will not be visible until the auction starts tonight.
Item 180430999571
Old 11-10-2009, 05:05 PM   #11
03clyde
CF Senior Member
03clyde's Avatar
Once spotted, the mods will remove the direct link to that auction - good luck anyways.
03clyde is offline
Old 11-10-2009, 07:27 PM   #12
NYC6
CF Senior Member
NYC6's Avatar
Ultimate 80's Sleeper.
NYC6 is online now
Old 11-11-2009, 06:31 PM   #13
OSHP1295
CF Senior Member
OSHP1295's Avatar
Awesome ride. Seen it on TB.com also. Gets alot of looks over there too. Goodluck with sale.
OSHP1295 is offline
Old 11-13-2009, 02:30 PM   #14
Nick McCardle
CF Member
8 hours left on the auction for those watching the thread that are interested.
11/14 edit: car sold outside of eBay. Now looking for a nice targa or frc m6 c5 for ~14k.
Reload this Page '87 Buick Turbo-T Limited, 32k Miles- GA
Closed Thread
Tags
87, buick, corvette, forum, forums, houston, lc1, limited, options, paint, powermaster, sale, scanmaster, terry, turbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
