Corvette Forum
Go Back   Corvette Forum > Off Topic > Other Cars
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-16-2009, 12:14 AM   #1
wilson34
CF Senior Member
wilson34's Avatar
Default Car Dies After 5-10min
What do you think the problem could be if a fuel injected car dies after driving around 5-10min.
Could it be fuel related, or faulty crank/cam sensor etc.
Melted fuses?
Anyone with ideas?
wilson34 is offline   Reply With Quote
Old 09-16-2009, 03:37 AM   #2
Orphan
CF Senior Member
Orphan's Avatar
What does it idle at before it dies? Most(if not all) FI cars will idle high when cold and idle down when the temp comes up to operating temp. If the bypass channels in the throttle body are clogged with gunk, It's very likely that the motor will choke itself out when the engine drops the RPM's.
The first step I would take is to take the throttle body off and give it a good hose down with carb cleaner.
Orphan is offline   Reply With Quote
Old 09-16-2009, 01:46 PM   #3
knyght4
CF Senior Member
knyght4's Avatar
Send a message via AIM to knyght4
Make/Model, Year, Mileage?
knyght4 is offline   Reply With Quote
Old 09-16-2009, 04:03 PM   #4
WAwatchnut
CF Senior Member
Support Corvetteforum!
WAwatchnut's Avatar
Definitely need to know more details.
Some cars have had problems with their Idle Air Control Valves. They use a stepper motor to open a valve to let more air in when the car's idling. But Subarus, and some VW's and Hondas I think, have had problems where the IACV get's gunked up, and needs to be cleaned (by spraying a cleaner, or cleaning the IACV itself), or if it's been gunked up for long, the motor's coils burn out, and the whole unit needs to be replaced.
Or it could be something completely different... knowing which car will definitely help identify any common issues.
(BTW- I think I may just be repeating Orphan's comment above... )
WAwatchnut is offline   Reply With Quote
Old 09-16-2009, 07:02 PM   #5
wilson34
CF Senior Member
wilson34's Avatar
Hey guys its a 1996 Eagle Talon turbo.
Heres the scoop, after the car warms up, the electronics start to lose power..ie
The power windows and wipers move slower and eventually all electronics lose power and the lights completely go out.
The motor will run and eventually go out itself.
**Edit: Forgot the battery, alternator and IAC have all been replaced
It has to be in electrical related, like a fuse that is heating up or something.
Something electrical has to be going out due to heat.
Thanks for the continued help fellas
Old 09-16-2009, 07:03 PM   #6
wilson34
CF Senior Member
wilson34's Avatar
But the car can start right up normally but eventually after the process the battery dies.
Old 09-16-2009, 09:22 PM   #7
wilson34
CF Senior Member
wilson34's Avatar
It has to be in the charging system from the alternator to the battery or in the pigtails going to the voltage regulator or something.
Someone help me lol
Old 09-17-2009, 01:36 AM   #8
Orphan
CF Senior Member
Orphan's Avatar
If the battery and the alt are new, I would check the alt fuse going to the battery. The circuit going from the alt to the battery is fused (so it doesn't blow the battery) so it may be corroded terminals to the fuse or the fuse itself.
Reload this Page Car Dies After 5-10min
Tags
10, car, dies, min
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
