Corvette Forum
Go Back   Corvette Forum > Off Topic > Other Cars
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-25-2009, 11:42 AM   #1
Bullet
CF Senior Member
Bullet's Avatar
Default Help with '02 GMC Yukon rough cold idle.
I have a 2002 GMC Yukon with the 5.3 liter engine and 114k miles. When it is below 38 degrees, it idles really rough and eratic jumping from what seems to be the choke on then off and then to below 500 rpms and almost dying. When it is above 40 degrees, it idles perfect. I took it to a local auto parts store for the codes to be read and it said bank 1 and 2 lean and bank 2 O2 sensor. I replaced the sensor and it helped somewhat due to the fact that once it is warmed up, it idles fine. To date, this is what I have done....
new fuel filter, new plugs and wires, new battery, fuel injectors cleaned with the machine, a couple of bottles of sea foam, non-ethonal gas in the tank, throttle body cleaned-wasn't dirty to begin with. I had the fuel pump checked by a local shop and they said the pressure was good according to their machine.
Is there an idle sensor of some sort? I haven't checked the codes again since having the check engine light come back on after the reset.
Bullet is offline   Reply With Quote
Old 01-25-2009, 11:48 AM   #2
GMautotech
CF Senior Member
GMautotech's Avatar
Based on your lean codes I think your intake gaskets are leaking vacuum. That has been a common problem for those engines. I would also clean the MAF sensor.
__________________
David - 07 LMB A6 1LT Z51 QX1
Mods: Free Paddle Shifter Mod - LPE CAI - 160 stat - mechanical O2 sims from cbrf4i1
Kooks LT's + off-road X + Bullets = the sound of music
Added steering wheel radio controls and HUD
www.reichertwoodstock.com/
GM VIN reports, build dates and recall info - PM me with your email addy and VIN (98 and newer only)!
GMautotech is offline   Reply With Quote
Old 01-25-2009, 11:57 AM   #3
Bullet
CF Senior Member
Bullet's Avatar
Quote:
Is there a "correct" way to clean the MAF sensor? Should I remove it and spray carb cleaner through the honey comb looking screen?
Compressed air?
Old 01-25-2009, 06:23 PM   #4
Bullet
CF Senior Member
Bullet's Avatar
Well, the MAF looked clean as the day it left the factory, but I went ahead and hit it with a little compressed air being careful not to damage the little hair looking wire things. Intake Manifold gaskets huh?
Old 01-25-2009, 07:24 PM   #5
TheCartel
CF Senior Member
TheCartel's Avatar
Maf is cleaned with a can of brake cleaner. Although a dirty maf will typically cause it to run rich. It could be something with the IAT sensor, I don't think a vacuum leak is temp. sensitive. I'll keep thinking about it....
TheCartel is offline   Reply With Quote
Old 01-27-2009, 05:56 PM   #6
best_vette_yet
CF Senior Member
best_vette_yet's Avatar
Quote:
Actually they make a MAF Cleaner called,,,,you guessed it Mass Air Flow Cleaner. It's made by CRC ,, it's in a gray spray can and you can find it at Advanced Auto Parts. Maybe else where too.
You need to find someone with a scanner that can look at all your engine sensors after your car has set over night. That way they can look at the temp sensors and compare them to the outside air temp. That's always the best place to start.
To find your vacuum leaks,,, if you have them the best thing to do is find someone with a "smoke" machine. Blow the smoke into your power brake booster vacuum line into your manifold without the engine running and look for the smoke to come out of your vacuum leaks.
Good luck.
best_vette_yet is offline   Reply With Quote
Old 01-28-2009, 08:03 PM   #7
Bullet
CF Senior Member
Bullet's Avatar
Quote:
That is what I am thinking......probably end up taking it to the Stealership, as much as I hate to - $$$$$
Old 02-10-2009, 11:12 PM   #8
Dr. Evil
CF Senior Member
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Dr. Evil's Avatar
Dont take it to the dealership. Buy a can of carb/choke cleaner. Brake parts cleaner works too. Start it up, spray it around the intake/head mating areas and listen for the rpm drop/rise. My money is on the intake gaskets. They are super easy to swap too.
Dr. Evil is offline   Reply With Quote
Reload this Page Help with '02 GMC Yukon rough cold idle.
Tags
2002, bank, chokes, clean, forum, gmc, iat, idle, locatin, locations, maf, o2, sensor, start, yukon
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
