2006 Escalade Keyless Entry
Hey guys,
I have a 2006 Escalade ESV Platinum and need to order a new key fob for the keyless entry. I found some part numbers but I''m not sure which one I need. On the back of the one Fob I have the # reads 15132197 and then the Model/FCC ID is LHJ011. I don''t know if that info is relevant.
I posted this on Cadillacforum.com but apparently they don't get much traffic over there. So I was hoping maybe one of you guys will know or have the ability to look up the info.
The part numbers I was able to find online are as follows:
21997126
Description: All Models, Specific Frequency
21997127 (listed 3 times)
Description: All Models, AMF
and also Seperately listed with the description: Specific Equipment option
And again with the description: All Models, Keyless Entry
93442413
Description: All Models, Low Frequency
So Im wondering which of those I should buy if theres a specific one that I need or if one is better than the others. Any help would be appreciated.
Thanks in Advance,
Dan
21997126
93442413
Thanks in Advance,
Dan
Pretty sure the Hummer and Denali use the same fobs........ I dont know the answer but Im on the Hummer forums quite a bit and there are quite a few guys over there that really know their stuff, maybe give it a try. here is the link for you.
http://www.elcovaforums.com/forums/index.php
I just checked the 2 fobs from the H2, one of them is the original #1 fob with the original key.... the second fob is from the GMC dealer with a GMC key programmed at GMC (my friend worked at a GMC dealer when we bought the H2, it was traded for a Denali XL). The original fob has the following ID: GM 15132197 Model/FCCID LHJ011
the second fob has the following ID: GM21997127 Model/FCCID LHJ011
Hope this helps you out some..... good luck.
