To my Jeep friends
To my Jeep friends
Gents. I do not have an owner's manual yet, ordered one from Ebay. I found a brand new set of 5 wheels and tires from a new Rubicon. Price is great. Anyone know if the offset and bolt pattern is compatible from a 97 Wrangler to present day config. on Rubicons, and early 200_ Sahara's?
Rubicon says it is a 5 x 5 pattern. I need to join a Jeep forum but haven't really found one yet.
Grats,
DD
Grats,
DD
Grats,
dd
Any TJ, 97 though I believe 04.
DD - All TJs are the same bolt pattern.
The forum you want is http://www.rubiconownersforum.com/phpbb2/index.php- even if you do not have a Rubi, the guys are a great bunch and the tone on the board is positive and mature.
DD
Decent forum recommendation: www.colorado4x4.org It's a fairly civil group, and the tech section is good.
My (off pavement) rig:
Thanks you guys. I just got my owner's manual from E-bay. This is my first Jeep, I hope to have some casual fun with it, nothing major, just a weekend fun toy. Any experience with rear seal leaks? I hear they're pretty common.
DD
DD
Crank, trans, transfer case, or axle/pinion, or wheel bearing seal?
Some folks get a small leak from the TC rear seal, but it's a piece of cake to replace- just drop the driveshaft and pop a new one in.
Post up with more complete info- pulling the oil pan is a bit tricky, but I can hopefully offer a tip or two- BTDT a few times.
Actually, I haven't really isolated the leak yet. It's a real mess around that big skid plate. I haven't built up the nerve to get down there and remove it yet to look around. I picked up this Jeep for a song and it has 142K, but in excellent shape, inside and out. Only immediate issue is this leak. It definately looks like trans. fluid, certainly not motor oil. Auto trans. Thanks.
dd
dd
I took a closer look this morning before work. I do have a small leak at the rear transfer case, and I'm certian that the central leak is auto trans fluid. I wanted to removed that large skid plate and take a look around but it kinda appears to be supporting some stuff. I don't want to drop it and not be able to get it back on there. I'm gonna get a Chilton's manual this weekend and so some reading up.
Dd
Dd
Location: I speak the truth. Harsh but accurate. The Woodlands Texas
1 Post
St. Jude Donor '09-'10
I have 8500 mile on my 07 Sahara Unlimited and I picked it up at the end of May.
