Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-04-2013, 05:55 AM   #1
s'noJob
CF Senior Moments
Support Corvetteforum!
s'noJob's Avatar
Default What's the difference between a Small Block & Big Block V8?
I know the straight vs AFU answer ratio is going to be high on this one.
Yeah, I get it:
small block BIG BLOCK
But I've heard these terms for years and never really understood the distinction.
__________________
2004 A4 Arctic White Coupe
Blackwing Intake -- Corsa Sport Exhaust with X-pipe -- BFG Sport Comp2 G-Force tires -- C6 Z51 Sway Bars -- Bilstein Shocks -- Hi, Lo, & Fog HIDs -- 3.15 Performance Axle -- NGK TR55 Plugs -- Russell Stainless Steel Brake Lines -- Custom Dyno Tune by Mayhem Motorsports
~ If I'm feeling a bit light-headed, does that mean I don't need a H.A.N.S?
s'noJob is offline   Reply With Quote
Old 12-04-2013, 06:00 AM   #2
MillertimeZ06
CF Senior Member
MillertimeZ06's Avatar
I've never really understood the difference between something small or big either
MillertimeZ06 is offline   Reply With Quote
Old 12-04-2013, 06:11 AM   #3
CHASLS2
CF Senior Member
St. Jude Donor '13
CHASLS2's Avatar
One weighs more than other also.
CHASLS2 is offline   Reply With Quote
Old 12-04-2013, 06:17 AM   #4
siege101
CF Senior Member
siege101's Avatar
Send a message via AIM to siege101
As far as I know, its just that. One is bigger than the other.
siege101 is online now   Reply With Quote
Old 12-04-2013, 06:22 AM   #5
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
There is no exact definition to answer the question you seek, only generalizations, but excess meaningless passion.
Some engines fit well into a so-called small block/big block categorization, e.g. small block chevy (265, 283, 302, 305, 307, 327, 350, etc.) and the big block chevy (396, 427, 454), and some don't, e.g. Pontiac some Mopar V-8s. Add to that some large displacement engines are boat anchors while some large displacement engines are smaller blocks.
Easy Rhino is offline   Reply With Quote
Old 12-04-2013, 06:27 AM   #6
Jughead
Senior Member since 1492
St. Jude Donor '09
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell. 3. Islam is the enemy.
Send a message via AIM to Jughead
that is my understanding as well. SB also referred to as a Mouse and BB called a Rat. I have a RAT.
Jughead is offline   Reply With Quote
Old 12-04-2013, 06:29 AM   #7
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
Quote:
But the BB is also called the porcupine engine, and the Hemi called the elephant.
Old 12-04-2013, 06:30 AM   #8
Jughead
St. Jude Donor '09
Jughead's Avatar
I never heard that about the Hemi, but I'm hardly a Chrysler groupie.
Old 12-04-2013, 06:34 AM   #9
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
Have you heard the jole about the duck and the nailhead Buick?
Old 12-04-2013, 06:54 AM   #10
Jughead
St. Jude Donor '09
Jughead's Avatar
must be before my time.
Old 12-04-2013, 06:58 AM   #11
SouthernSon
CF Senior Member
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports Track Crew Chief Support
Those little nail heads back in the 60's could fly! Even had two 4 barrels on some of them. The old rivieras were great.
As far as BB vs. SB, the torque difference is considerably different but I guess the physical size difference is the defining word. But, a small block overhead cam engine is probably larger than a BB pushrod.
SouthernSon is offline   Reply With Quote
Old 12-04-2013, 07:15 AM   #12
TerryL
CF Senior Member
TerryL's Avatar
The current Vette motors are all SB's right? The base 364ci (and) the 427? Larger cubic inch but from a SB not the old BB. Boring and/or changing the stroke can add cubic inches to a motor but starting with a BB usually gives you more to...work with. 265s grew into 283s and then 327s and even a 383 'stroker' but never into 396 or 427s. They started as BBs.
TerryL is offline   Reply With Quote
Old 12-04-2013, 07:41 AM   #13
jim2527
CF Senior Member
jim2527's Avatar
Send a message via MSN to jim2527
Small blocks have a bore spacing of 4.4"
Big Blocks have a bore spacing of 4.84"
Bore spacing is the distance between the centerline of the pistons.
Wider bore spacing allows for larger pistons. Larger pistons require bigger blocks.
Small block and big block engines have essentially the same bore and stroke at 400 cid.
jim2527 is offline   Reply With Quote
Old 12-04-2013, 07:47 AM   #14
jim2527
CF Senior Member
jim2527's Avatar
Quote:
Kind of sort of..
The 'new' LS engines have the same bore and bore center line as the old SBC. The old SBC's were available as 400's.
At 400 cid the LSX has a similar bore and stroke the old BBC. At 427 cid its similar as well. 427 is about the max displacement for a LSX engine due the bore size. BBC can go up to 572 cid or so due its much larger bore size.
Old 12-04-2013, 08:03 AM   #15
Capt Van
CF Senior Member
St. Jude Donor '12
Capt Van's Avatar
Location: Cameron Stockwell's Recovery Road Grand Rapids, MI. But still live in ViperFish, (SW) Florida
This is a small block, 283/245
This is a small block 427 (ZR1)
This is a big block 427/400
This is a great big block 10 cylinder 2014 Viper
Capt Van is offline   Reply With Quote
Old 12-04-2013, 08:15 AM   #16
pappy.72
CF Senior Member
pappy.72's Avatar
Quote:
Originally Posted by Capt Van View Post
This is a small block 378 (ZR1) (The Z06 has the 427)
Click the image to open in full size.
fixt
pappy.72 is offline   Reply With Quote
Old 12-04-2013, 08:38 AM   #17
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
The Mouse and Rat distinctions are for Chevrolet engines only.
I've asked this question before also. I phrased it a bit differently though as I asked what the defining characteristic is between the two. I have never gotten an answer to the defining characteristic. I know it is NOT displacement or physical dimmensions. Yes I understand that they are physically larger on the big block, but at what point does the engine change from being considered a big block or small block. We have 383 big blocks and some smaller displacement engines are also big blocks. We also have 454 small blocks and 454 big blocks.
Could it be the bore to stroke ratio? Longer stroke than bore size equating to a big block maybe? Or can you have a small block with a longer stroke than bore?
Or could it be deck height?
JetMechZ16 is offline   Reply With Quote
Old 12-04-2013, 08:44 AM   #18
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
This would be true for one engine manufacturer, but not all.
Different engine manufactuerers have different bore spacings. i believe deck height also plays a role.
Old 12-04-2013, 08:44 AM   #19
lakota
CF Senior Member
Add original Chevy BB 348 which became 409, both had scalloped valve covers.
https://www.google.com/search?q=348/...KpsASnvYH4DQ&v
lakota is offline   Reply With Quote
Old 12-04-2013, 09:07 AM   #20
nate99
CF Senior Member
nate99's Avatar
Interesting question, but there is no science to the terms. It's mostly just what car guys have colloquially adopted as a distinction over the years. If you have read magazines like Hot Rod or Car Craft for a couple of decades, you probably have it sorted out.
GM/Chevy decided to use the "small block" descriptor that had been used for decades for the 265-400 c.i. family of 4.4" bore spaced V8's on the new LS engines that retained the 4.4" bore spacing, but essentially nothing else from the earlier engines.
Chevy exclusively used the same two blocks for so long, it made sense, but other manufacturers had engines come and go (or be modified more extensively) on a more regular basis that the comparison doesn't make much sense. A big block Ford is generally understood to be the 460 block, but the Ford FE was in between that and the Cleveland and Windsor V8's, so it doesn't make as much sense. Mopars had the LA engines that were their smallest V8's, but they had the B engines that went up to 440 ci and the Hemi engines that went to 426 from the factory.
Some call the shorter deck 350 and 403 Olds motors "small blocks", but they are otherwise architecturally the same (bore spacing, etc.).
nate99 is offline   Reply With Quote
Reload this Page What's the difference between a Small Block & Big Block V8?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Boat experts, what engine is best for this size boat? Zeek Off Topic 45 08-20-2013 12:18 PM
SS700 Keisler In A 67, Anyone Performed This Installation? cordova67 C1 & C2 Corvettes 22 03-08-2013 08:12 AM
radiator size bludorbronc C3 General 6 09-09-2012 09:17 PM
Small vs Big Block? jost6453 Engine Mods 13 08-29-2012 09:26 PM
NON Corvette - Small Block Big Block Performance Parts Vintage Parts BOSTONCAMARO C3 Parts for Sale/Wanted 5 07-30-2012 05:46 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
