Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2012, 02:39 PM   #1
Jamesnns
CF Senior Member
Default Need ideas for DIY replacement patio table top.
Our patio table top has broken three times. We're in NW Indiana and plus the location of our house..ect, means we get some strong winds out back. Our patio table has been flipped three times now, resulting in broken glass everywhere.(yes, the umbrella was removed)
It measures 39x63" rectangular shape with rounded corners.
I was thinking about using plywood, but I'd need to cut a hole in the center for the umbrella, which is fine...and I thought about topping that with ceramic tiles ..but I don't have a tile cutter...and the edges of the top base are rounded as well.
Any ideas on what I could use that would hold up to the rain and that's a material I can work with? What can I make a cheap top out of?
I've got the usual tools..table saw, miter/chop saw, drills, saws-all....
$$ are tight right now.
Jamesnns is offline   Reply With Quote
Old 03-17-2012, 02:41 PM   #2
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
Marine plywood top cut to fit and tiled.
For small tile jobs you can manage with a cheap manual cutter.
Easy Rhino is offline   Reply With Quote
Old 03-17-2012, 03:43 PM   #3
Jamesnns
CF Senior Member
Nevermind...my neighbor has a wet saw for cutting tile...
So Ill base it in plywood and top it in my left over tile from the bathroom job.
My neighbors a really nice guy......
Old 03-17-2012, 04:02 PM   #4
CP
CF Senior Member
CP's Avatar
Big piece of plexiglas.
CP is offline   Reply With Quote
Old 03-17-2012, 04:58 PM   #5
KarlK
CF Senior Member
KarlK's Avatar
concrete
KarlK is offline   Reply With Quote
Old 03-17-2012, 05:46 PM   #6
JJ Deuce
CF Senior Member
JJ Deuce's Avatar
We had an outdoor coffee table with an ugly plexiglass top. To replace it, I used a piece of hardie board, then used silicon to affix the caps and grouted them with sanded grout. Then topped it all with two part epoxy.
Click the image to open in full size.
Took me awhile to get all the raw materials together.
JJ Deuce is offline   Reply With Quote
Old 03-17-2012, 05:50 PM   #7
vvv90
CF Senior Member
Sounds like a lot of time invested in a patio table top.
Invest, and I can't stress the word "invest" enough in a nice solid set of cast aluminum patio furniture. We get just about the worst wind imagineable and they don't budge a mm. I'm not talking about that aluminum crap you see at Home depot. I'm talking about the Hanamint cast aluminum that weighs about 25 pounds per chair.
This stuff is indestructible and after 14 years I have a few paint chips, but no serious deterioration or rusting or corrosion.
I only say this because I've been through all that cheap crap.
This stuff will be given to my grand kids that's how strong it is.
vvv90 is offline   Reply With Quote
Old 03-18-2012, 12:08 AM   #8
tjfontaine
CF Senior Member
tjfontaine's Avatar
You will struggle with this as long as the table is cheap and light.
My brother has same issue ... meanwhile my 25 year old STEEL patio set is heavy, solid, and does not move when strong winds come along.
tjfontaine is offline   Reply With Quote
Old 03-18-2012, 12:13 AM   #9
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
Although I still have a 21 year old expanded steel metal set, the cast aluminum is FTW.
I should state for clarity sake that I have four outdoor sets currently, having just got rid of one old hacker set.
Old 03-18-2012, 12:30 AM   #10
KWIL
CF Senior Member
St. Jude Donor '12-'13
KWIL's Avatar
That's pretty cool. How much epoxy did you use and how much did it cost?
KWIL is online now   Reply With Quote
Old 03-18-2012, 12:36 AM   #11
BobbyC3
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13
BobbyC3's Avatar
Location: Common courtesy and common sense are not common.
BobbyC3 is offline   Reply With Quote
Old 03-18-2012, 01:28 AM   #12
Skid Row Joe
CF Senior Member
Skid Row Joe's Avatar
Location: Direct donor to St. Jude ~ so don't ask. ;) Dallas, Texas
This.......
Skid Row Joe is offline   Reply With Quote
Old 03-18-2012, 02:42 AM   #13
Olustee bus
CF Senior Member
Olustee bus's Avatar
Hardie board is pretty nice at first but it must have good support. It will absorb water and begin to sag and finally "melt. The silicon top may help that situation. It is certainly a good looking table.
Olustee bus is offline   Reply With Quote
Old 03-18-2012, 05:58 PM   #14
Jamesnns
CF Senior Member
But...$$ are tight right now...I don't see the available cash coming in to buy a new set right now...so I'll need to make due with what Ive got for this summer.
Old 03-18-2012, 06:31 PM   #15
tjfontaine
CF Senior Member
tjfontaine's Avatar
Anything then to add weight to it so it doesn't float away ... or anchor it down.
Old 03-18-2012, 06:39 PM   #16
nj02vette
CF Senior Member
nj02vette's Avatar
Location: Marlton. Increasing performance one speeding ticket at a time! NJ
Going to have to agree with all above. We replaced a patio set that was left here by the previous owners because the sling chairs started ripping. We had used this set for years and it was high quality (forget the brand). I looked into a replacement set of slings and they were $350 each . I said eff that, and bought a complete patio set for $500. Wind picked it up and shattered the glass after a week. That's when I learned there was a difference between a $3000 patio set and a $500 one.
I did the same things as you're thinking. Got a plexiglass top and it lasted a year. I made a top out of plywood (can't use pressure treated) and finished it with tile. It lasted a few seasons before the tiles started cracking due to the expansion of the wood.
In the end, getting a new HEAVY table with wrought aluminum top solved all the problems. Now that won't go anywhere, even with the umbrella up in a hurricane.
nj02vette is offline   Reply With Quote
Old 03-18-2012, 06:39 PM   #17
Aerovette
CF Senior Member
Aerovette's Avatar
If you use tile and it blows over, you are still going to have damage. I would thing plywood would be the way to go.
Aerovette is offline   Reply With Quote
Old 03-18-2012, 07:48 PM   #18
JJ Deuce
CF Senior Member
JJ Deuce's Avatar
Quote:
The epoxy was a kit from Michael's craft store. I think it was around 20 bucks and made a little over a quart. If I remember right it is supposed to be roughly equivalent to 100 coats of varnish. I did a smaller table at the same time. It has yellowed quite a bit being outside but we like the weathered look. That picture is two or three years old.
Sorry for the hijack. On a related note, that table is part of a set my grandparents bought 30+ years ago. We have a dining table and 4 chairs (all expanded metal), a sofa and two lounge chairs (with cushions) and a smaller table like the one pictured. I am going to repaint them this summer but they are in good shape overall and the wind doesn't move them.
Old 03-18-2012, 09:43 PM   #19
rkhegler
CF Senior Member
rkhegler's Avatar
Here ya go! You can do it!
http://ceramicartsdaily.org/pottery-...on/?floater=99
rkhegler is offline   Reply With Quote
Old 03-18-2012, 09:59 PM   #20
LarryMJones
CF Senior Member
St. Jude Donor '13-'14
LarryMJones's Avatar
I need two about the same size.
I was thinking of smoked plexiglas. There is a plexiglass outlet nearby and it's on my to do list before summer.
One of mine ended up in the pool. A bizillion 1/4 inch pieces of bronze tempered glass. It took all summer to find all the pieces.
LJ
LarryMJones is offline   Reply With Quote
Reload this Page Need ideas for DIY replacement patio table top.
Tags
14, broken, diy, epoxy, glass, idea, ideas, make, patio, piece, plexiglass, replacement, table, tile, top
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
