Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-22-2011, 08:09 PM   #1
touringmike
CF Senior Member
touringmike's Avatar
Default OK all you S10 Blazer saggy door/hinge pin challanged *****, I found the cure....
Feel free to us it.
Click the image to open in full size.
touringmike is offline   Reply With Quote
Old 08-22-2011, 08:10 PM   #2
CHASLS2
CF Senior Member
St. Jude Donor '13
CHASLS2's Avatar
It needs a 6.2 swap.
CHASLS2 is offline   Reply With Quote
Old 08-22-2011, 08:33 PM   #3
thetaxman
CF Senior Member
you might be a redneck......
thetaxman is offline   Reply With Quote
Old 08-22-2011, 08:34 PM   #4
TPFKATK
CF Senior Member
Support Corvetteforum!
TPFKATK's Avatar
Awesome.
A pterodactyl pooped on your hood.
TPFKATK is offline   Reply With Quote
Old 08-22-2011, 09:07 PM   #5
touringmike
CF Senior Member
Quote:
Originally Posted by TPFKATK View Post
Awesome.
Nah.
Just didn't do the "wax off" procedure yet.
Old 08-22-2011, 10:17 PM   #6
thetaxman
CF Senior Member
Quote:
Originally Posted by touringmike View Post
Nah.
I'd say a bit too much waxing off.....
Old 08-22-2011, 10:19 PM   #7
pkazsr
CF Senior Member
Cruise-In X Veteran
St. Jude Donor '09
pkazsr's Avatar
I have to lift the door of my S10 to close it so I made the mistake of clicking on this thread.
pkazsr is offline   Reply With Quote
Old 08-22-2011, 10:36 PM   #8
blown87
CF Senior Member
GA Events Coordinator
blown87's Avatar
Got a 20$ that says "Meth" may have helped a bit on that mod.
But all the GM's with that POS hinge have that problem, I bet the shop has done a hundred of them.
blown87 is offline   Reply With Quote
Old 08-22-2011, 11:05 PM   #9
J S Machine
CF Senior Member
St. Jude Donor '10-'11-'12-'13
St. Jude Knife Maker
J S Machine's Avatar
My '95 Z71 has the same sagging hinge problem...aggravating as fire..
J S Machine is offline   Reply With Quote
Old 08-22-2011, 11:51 PM   #10
99mallett
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
99mallett's Avatar
Location: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
This was parked next to me a while back...
99mallett is offline   Reply With Quote
Old 08-23-2011, 12:14 AM   #11
blown87
CF Senior Member
blown87's Avatar
Quote:
Why don't you repair it before it really gets expensive.
Once you have to break out the welder, it tends to get into you check book.
Old 08-23-2011, 04:13 AM   #12
Black94LT1
CF Senior Member
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12
Black94LT1's Avatar
If it is just the bushings, it is an easy and cheap fix, about $10 and an hours work.
Black94LT1 is offline   Reply With Quote
Old 08-23-2011, 07:10 AM   #13
J S Machine
CF Senior Member
Quote:
Where can I find the bushings?
Another thing, there is a small piece in the hinge assembly which looks like a flat piece of metal with indentions. These little indentions ride on the protruding downward hinge pin, and position the door at the several stop points as it is being opened. The force from the spring and /or repeated openings and closings caused the little flat piece to break off the bottom of the hinge pin. The doors still open and close fine, but if I am parked on a hill they will not open and stay open at all.
I asume the only fix is to replace that pin, which would be fine to do if I were putting bushings in.
Old 08-24-2011, 07:37 PM   #14
Black94LT1
CF Senior Member
Black94LT1's Avatar
The pins and bushings are avialable in the "help" section at any box parts store (autozone, etc). I'm not sure on the hold open portion, that may not be as easy to fix as that part is part of the hinge itself if I recall correctly.
Here is a pretty good link on the process to replace the bushings. I did most of mine by using various sockets and C clamps to press parts in and out rather than using prybars, hammers, punches, etc, but whatever works best for your situation.
http://www.bodyshopzone.com/archives...replace_1.html
Also, if you are looking for the tool to remove and replace the spring, I found one at Harbor Freight for about $4 or $5, compared to $30 or so I was finding on-line.
Reload this Page OK all you S10 Blazer saggy door/hinge pin challanged mofos, I found the cure....
Tags
10, blazer, change, door, doors, fix, hinge, hinges, kit, pin, pins, repair, replace, replacement, s10, saggy, sale
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
