Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-04-2010, 10:59 AM   #1
chuckster
CF Senior Member
chuckster's Avatar
Send a message via AIM to chuckster
Default How Much Weight can be stored in the attic over the Garage?
Ok, I know this is going to bring out the contractors..
I have a 2 car garage with a folddown ladder to get up to the attic. The trusses are have about a 10' wide by maybe 4 ' high space. There is already plywood down.
I want to store my steel hurricane panels up there..I think the rafters are 24" OC..
The Panels are Corrugated Steel about 18" wide by 6' high. maybe 30 or so...
With the load spread out across the floor, should it be able to handle it?
Click the image to open in full size.
chuckster is offline   Reply With Quote
Old 10-04-2010, 11:01 AM   #2
pewter-FRC
CF Senior Member
pewter-FRC's Avatar
5 lbs less than its capable of holding
i'll be here all week
/thread
pewter-FRC is online now   Reply With Quote
Old 10-04-2010, 11:05 AM   #3
1Patriot
CF Senior Member
1Patriot's Avatar
How much does each panel weigh that you intend to store?
An attic floor that has a plywood deck will hold a lot of weight but stop before the sag. Moving around topside with long shutters may become the hard part.
1Patriot is offline   Reply With Quote
Old 10-04-2010, 11:16 AM   #4
smearig
CF Senior Member
smearig's Avatar
Draw a diagram of the truss in profile view.
smearig is offline   Reply With Quote
Old 10-04-2010, 11:35 AM   #5
pewter99
Auctioneer Administrator
Organizer St. Jude Fundraiser
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
I believe in the Beer Fairy
Support Corvetteforum!
pewter99's Avatar
hurricane panels = deceased SO
pewter99 is offline   Reply With Quote
Old 10-04-2010, 11:36 AM   #6
smearig
CF Senior Member
smearig's Avatar
Quote:
Oh. I'm sure that it will hold that.
Old 10-04-2010, 11:38 AM   #7
chuckster
CF Senior Member
chuckster's Avatar
Old 10-04-2010, 11:38 AM   #8
Swany00
CF Senior Member
Swany00's Avatar
has it held you?
Swany00 is offline   Reply With Quote
Old 10-04-2010, 11:38 AM   #9
chuckster
CF Senior Member
chuckster's Avatar
Quote:
I'll shoot a picture when I get a chance..
Old 10-04-2010, 11:43 AM   #10
ZipZap
CF Senior Member
St. Jude Donor '07-'08-'09-'10
ZipZap's Avatar
Location: Time flies like an arrow. Fruit flies like a banana.
What are the main truss joists? Engineered? Dimensional lumber? What size?
ZipZap is offline   Reply With Quote
Old 10-04-2010, 11:44 AM   #11
blademaker
CF Senior Member
St. Jude Donor '10
Location: Democracy is two wolves and a lamb voting on what to have for dinner. Liberty is a well armed lamb contesting the vote.
How much would you estimate them to weigh?
blademaker is offline   Reply With Quote
Old 10-04-2010, 12:05 PM   #12
LarryMJones
CF Senior Member
St. Jude Donor '13-'14
LarryMJones's Avatar
My neighbors fell in. The contractor did a poor job of structural work, not intended for an attic load. I had my builder repair it for him by adding a beam below the ceiling and sheetrocking it in. His garage ceiling was 9 ft so adding a 12 inch beam didn't cause a problem.
My last house a 2 story with basement garage below the main floor, the builder got nervous and added a 3 inch steel colum in the center of the 2 car stalls to support a 22 ft long beam.
It didn't seem like a problem when we bought the house but it screwed up the center isle for walking between vehicles.
LJ
LarryMJones is offline   Reply With Quote
Old 10-04-2010, 12:11 PM   #13
chuckster
CF Senior Member
chuckster's Avatar
Quote:
Originally Posted by LarryMJones View Post
My neighbors fell in. The contractor did a poor job of structural work, not intended for an attic load.LJ
What did he put up there?
Old 10-04-2010, 12:14 PM   #14
DAB
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
St. Jude Donor '10
DAB's Avatar
Quote:
late night heffalump party....
DAB is offline   Reply With Quote
Old 10-04-2010, 12:49 PM   #15
LarryMJones
CF Senior Member
Usuall attic junk. It was 3 stalls wide, but a really poor framing job. But typical of residential construction around here. If I had to guess the origional framing plan was modified to make a 3 stall garage out of what was to be a 2 stall.
Mine is 3 stalls wide, no columns, but they used T beams in lieu of joists.
LJ
Old 10-04-2010, 02:08 PM   #16
chuckster
CF Senior Member
chuckster's Avatar
Pics posted at top
Old 10-04-2010, 02:25 PM   #17
chuckster
CF Senior Member
chuckster's Avatar
I posted a few pics..
Old 10-04-2010, 05:22 PM   #18
chuckster
CF Senior Member
chuckster's Avatar
Ok where are the experts?
Old 10-04-2010, 05:26 PM   #19
Swany00
CF Senior Member
Swany00's Avatar
It appears that you've already put them up there, since they haven't fallen, it's my professional opinion that they'll hold
Old 10-04-2010, 05:43 PM   #20
LarryMJones
CF Senior Member
You don't have to worry about snow loading, and you have already tested it I see.
By any chance did you measure the ceiling height before and after you put that much weight up there.
Just look at the bottom chord of the trusses. The way they are loaded with metal and plywood floor stacked on the bottom cord you are putting all the stress on the nailed joints of the bottom cord. Not good. The truss is designed for a load on the roof so that the entire truss is carrying the load.
I would recommend some all thread rod reinforcing of the bottom cord connection, before the nails pull out. You might want to put some temporary colums below untill it's reinforced.
That truss is just not designed to be loaded that way. Remember the Kansas City Motel walkway that gave way killing several people. It failed because of the hanger rods connections not the structure.
Just look at those nailer joints, they are for truss loading from the roof, placing the nailed joint in compression. With weight on the joist they are now in tension.
LJ
Reload this Page How Much Weight can be stored in the attic over the Garage?
Tags
attic, bottom, cord, garage, hold, put, rafter, store, stored, support, truss, trusses, typical, weight, wiegt
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
