Corvette Forum
Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-22-2009, 11:31 AM   #1
jasper711
CF Senior Member
Default Need cost for well and septic system
Anybody have recent experience having a well drilled and pump installed? I realize this will vary much based on location and depth, etc. but would like to know the ballpark. Does that run $700? $7000?
Same deal for a septic tank. Once again it is understood this will depend on local drainage, number of bedrooms etc but I am curious of order of magnatude.
I am looking at bare properties for a minimal cabin and need to know what allowance to figure for putting these things in.
Thank you
jasper711 is online now   Reply With Quote
Old 11-22-2009, 11:45 AM   #2
ter
CF Senior Member
ter's Avatar
I had to replace the pump and the pipe in an existing well, and it was 2200.00. The well depth was 370 feet. Like you said it depends.
So, generally I would like to have about 7K or so budgeted to install both in my area. Again it depends on the septic codes and soil etc.
For some camps around here, they don't use a septic field, just a holding tank, that must be pumped (by law) on an annual basis. Other guys rent a porta jon for a month.
ter is offline   Reply With Quote
Old 11-22-2009, 11:46 AM   #3
Vettman 1
CF Senior Member
Vettman 1's Avatar
Majority of septics in my area (Ca. foothills) run approx. $20-$30K. Wells $13 ft. + pipe, pump, and wire. My well is 503 ft. deep
Vettman 1 is offline   Reply With Quote
Old 11-22-2009, 11:47 AM   #4
Nowhere Man
CF Senior Member
Nowhere Man's Avatar
http://www.facebook.com/home.php?
Send a message via AIM to Nowhere Man
Thank you
for your septic are you allowed to have drain fields or a sand mound. a sand mound will cost a lot more then a drain field. you are looking around 10K for a drain field and about 15K for a sand mound
Nowhere Man is offline   Reply With Quote
Old 11-22-2009, 11:49 AM   #5
Jeff78
CF Senior Member
Jeff78's Avatar
If you are just looking for water for a cabin and if the water level is under 30 feet below the surface just drive a point.
I had to get a well drilled last spring, they only had to go 42' down. Total cost was $5700.
Jeff78 is offline   Reply With Quote
Old 11-22-2009, 12:07 PM   #6
Olustee bus
CF Senior Member
Olustee bus's Avatar
In Northeast Florida, I think a well will run about 5 to 6 thousand and a septic tank and drainfield about 10 to 12 thousand.
If your area has a fluctuating water table, drill the well and plade the drain field on top of that.
Olustee bus is offline   Reply With Quote
Old 11-22-2009, 02:50 PM   #7
C5 Pewter Coupe
CF Senior Member
C5 Pewter Coupe's Avatar
Send a message via Yahoo to C5 Pewter Coupe
42 feet? I'd have hand dug it and saved that much money.. (or atleast got a portable drilling rig and done it yourself)
C5 Pewter Coupe is offline   Reply With Quote
Old 11-22-2009, 03:31 PM   #8
O'Shark
CF Senior Member
O'Shark's Avatar
Send a message via AIM to O'Shark
My 100' well was drilled in April, 2005. They installed an Aermotor pump, Fiberwound Signature 2000 tank, did backhoe work from well to house (50') and installed the pump control box. Total cost was $3300.
O'Shark is offline   Reply With Quote
Old 11-22-2009, 04:00 PM   #9
AU N EGL
CF Senior Member
AU N EGL's Avatar
Well $1500 to show up then $100 a foot drilled plus equipment
AU N EGL is offline   Reply With Quote
Old 11-22-2009, 04:39 PM   #10
jasper711
CF Senior Member
Thanks everyone. That was an eye opener. I think i'll budget $20k when purchasing a property and then work determinedly to avoid that expense.
Sincere thank you for the great information.
Old 11-22-2009, 04:39 PM   #11
ZPO
CF Senior Member
Support Corvetteforum!
ZPO's Avatar
Quote:
I thought about $10.00 a foot plus a base charge and other equipment charges , (ie; pump, tank etc.), was the going rate in Georgia. I would love to put one in on my place but it's not one of my better half's priorities.
ZPO is offline   Reply With Quote
Old 11-22-2009, 04:44 PM   #12
CHASLS2
CF Senior Member
CHASLS2's Avatar
Gonna cost a pretty penny anyway you cut it.
CHASLS2 is offline   Reply With Quote
Old 11-22-2009, 06:36 PM   #13
AU N EGL
CF Senior Member
AU N EGL's Avatar
Quote:
I have also seen it at $2500 to show up and $10 / foot
talk to several well companies
Old 11-22-2009, 07:21 PM   #14
kapayakapaya
CF Senior Member
kapayakapaya's Avatar
Just had my well pump burn out in May and for them to replace the pump and also change from pipe to PVC and run new wire down (120' deep), it was $1400.
kapayakapaya is offline   Reply With Quote
Old 11-22-2009, 07:31 PM   #15
CHASLS2
CF Senior Member
CHASLS2's Avatar
Quote:
Originally Posted by kapayakapaya View Post
just had my well pump burn out in may and for them to replace the pump and also change from pipe to pvc and run new wire down (120' deep), it was $1400.
ouch!
Old 11-22-2009, 08:00 PM   #16
dpigguy
CF Senior Member
dpigguy's Avatar
200' well, 2 hp pump, tank, wiring and everything else = $5k. Septic system is aerobic and also ran about $5k - both in no-rock clay areas of S. Texas.
dpigguy is offline   Reply With Quote
Old 11-22-2009, 10:45 PM   #17
LarryMJones
CF Senior Member
LarryMJones's Avatar
Well flow rate. If you find a deep well is just too costly for a cabin and you can get a low flow well 1 gpm or so at a shallow depth you might look into a 200 gallon plastic holding tank.
Rig you well pump on a float switch to keep the tank full and a booster pressure activated pump (available from marine dealers) for you fixtures.
I designed one for a friend in Aspen utilizing a 500 gallon tank and he installed it in his house there where water supply was only about a 1 gpm. It provided plenty of water for several people staying at the house. Running 8 hours overnight it stored up 480 gallons.
LJ
LarryMJones is offline   Reply With Quote
Reload this Page Need cost for well and septic system
Tags
2000, average, control, cost, indiana, inspection, northeast, northwest, oxford, pa, panel, septic, signature, system, tank, texas
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
