Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-16-2009, 06:33 PM   #1
germanc5
CF Senior Member
germanc5's Avatar
Default oops gasoline in a duramax
one of our guys put gasoline in the company duramax dually on a road trip. obviously they drove it a little ways and it quit. will there be any immediate or long term damage?
germanc5 is offline   Reply With Quote
Old 09-16-2009, 06:36 PM   #2
UniqueDoug
CF Senior Member
UniqueDoug's Avatar
I think it is fugged
UniqueDoug is offline   Reply With Quote
Old 09-16-2009, 06:37 PM   #3
roadracer247
CF Senior Member
roadracer247's Avatar
This is what happened to the last guy who tried this...
Click the image to open in full size.
roadracer247 is offline   Reply With Quote
Old 09-16-2009, 06:37 PM   #4
63C2splitter
CF Senile Member
St. Jude Donor '08
Support Corvetteforum!
63C2splitter's Avatar
Doesn't sound good. How much gas vs. amount of Diesel in the tank?
63C2splitter is offline   Reply With Quote
Old 09-16-2009, 06:38 PM   #5
JackDidley
CF Senior Member
JackDidley's Avatar
I'd say, its goof chinked.
JackDidley is offline   Reply With Quote
Old 09-16-2009, 06:40 PM   #6
KarlK
CF Senior Member
KarlK's Avatar
Drain the tank of gas, pull the fuel pump line, turn key to turn on pump and pump residual gas in the line.
Reconnect line, fill with diesel, turn key and cross fingers.
The above worked on a Powerstroke with "0" ill effects. Don't ask me how I know.
KarlK is offline   Reply With Quote
Old 09-16-2009, 06:43 PM   #7
germanc5
CF Senior Member
germanc5's Avatar
they're at the chevy dealer in western ky. right now. the service dept. said it should be fine but i was wondering if any one has close experience with an incident like this.
Old 09-16-2009, 06:43 PM   #8
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Corvette Kid's Avatar
Location: Not a loser who defines himself by being the 10,000th poster in an "epic" thread
Quote:
Good chance. The bad thing is, is that it was run until it quit. The damage could be severe.
Corvette Kid is offline   Reply With Quote
Old 09-16-2009, 06:46 PM   #9
Stoge
CF Senior Member
Stoge's Avatar
BadHammers BadHammers Simon Alexander BadHammers
We had a similar incident with a Yanmar diesel powered John Deere Pro Gator at work. We had to drain the tank & lines & replace the fuel filter. It has been running like normal since then.
Stoge is offline   Reply With Quote
Old 09-16-2009, 06:47 PM   #10
KarlK
CF Senior Member
KarlK's Avatar
Quote:
me
Old 09-16-2009, 06:48 PM   #11
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
C5Nate's Avatar
Psssst.....there is no "pump" to pump the fuel.
Depends on the mixture.
If it ran till it quit, then its probably toast.
Drain the tank, blow out the lines until the return line comes out clean.
Put about 5 gallons of diesel in the tank, prime the fuel up to the filter using the hand primer. Hope for the best.
IMHO, they have a the very least shortened the life expectancy of the diesel.
C5Nate is offline   Reply With Quote
Old 09-16-2009, 06:48 PM   #12
germanc5
CF Senior Member
germanc5's Avatar
me
doh!
Old 09-16-2009, 06:49 PM   #13
C5Nate
CF Senior Member
C5Nate's Avatar
Quote:
Yes, but you were not running down the highway at 70 mph either.
Old 09-16-2009, 06:51 PM   #14
KarlK
CF Senior Member
KarlK's Avatar
There is an electric pump on the 7.3 PSD's, not sure about Max's.
Mine ran till it quit, had 12000 miles on it. I did the above procedure. Filled it up, fired right up and I have not replaced an injector, pump, nothing. I have 150K on it now.
We've had a few service techs do the same on our Powerstoke service trucks with no damage.
Old 09-16-2009, 06:55 PM   #15
Stoge
CF Senior Member
Stoge's Avatar
Yeah and we're not turbocharged either, but I'll bet its still worth a try.
Why would speed matter?
Old 09-16-2009, 06:55 PM   #16
DarthStimpy
CF Senior Member
DarthStimpy's Avatar
Send a message via AIM to DarthStimpy Send a message via Yahoo to DarthStimpy
Unless it was at full boost there shouldnt be enough compression to ignite the gasoline, and therefore the engine just stalled. No harm.
DarthStimpy is offline   Reply With Quote
Old 09-16-2009, 09:01 PM   #17
C5Nate
CF Senior Member
C5Nate's Avatar
Putten around in a Gator VS 7,000 lbs of truck hauling azz down the highway. Lots more revolutions before it dies.
Old 09-16-2009, 09:03 PM   #18
hendrix68
CF Senior Member
St. Jude Donor '13-'14
hendrix68's Avatar
Shameful.
hendrix68 is offline   Reply With Quote
Old 09-16-2009, 09:03 PM   #19
C5Nate
CF Senior Member
C5Nate's Avatar
No pump on the Dmax. Suction feed to the filter.
Like I said earlier, depends on the mixture of diesel VS gas. May be fine but it had to hurt it some.
I put a couple gallons of gas in my diesel by accident when BP first came around. Friggen brits dont know that Green means diesel here in the states. Not reg. gas
Ran fine but that was a 10:1 mixture.
Old 09-16-2009, 09:19 PM   #20
JRD77VET
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
JRD77VET's Avatar
Send a message via AIM to JRD77VET
Quote:
Huh?? Diesels have more compression that gas engines. That's how the diesel fuel ignites
Used to be a local used car lot that specialized in nice low mileage cars.
The owner's wife grabbed an almost new MB diesel and filled it with gas before she left.
The engine grenaded a few miles down the road.
The owner was not happy
JRD77VET is offline   Reply With Quote
Reload this Page oops gasoline in a duramax
Tags
2005, 2006, clean, corvette, drain, duramax, expectancy, filling, gas, gasoline, life, pumping, put, reg, tank
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
