Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-12-2008, 11:46 AM   #1
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
Default How to convert 250V 20A outlet to 110V 20A?
In my "new" digs, there is apparently 250V (220V?) 20A service in the garage above where I've positioned my work bench.
The outlet looks like this:
Click the image to open in full size.
I don't have any use for that voltage, but could definitely use 110V 20A for my compressor, etc.
What do I need to do to convert to 110V 20A?
TIA
ProfMoriarty is offline   Reply With Quote
Old 12-12-2008, 11:48 AM   #2
Umrswimr
CF Senior Member
St. Jude Donor '05
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
Send a message via AIM to Umrswimr
An electrician.
Umrswimr is offline   Reply With Quote
Old 12-12-2008, 11:48 AM   #3
cadams
CF Senior Member
cadams's Avatar
you need a step down transformer.
cadams is offline   Reply With Quote
Old 12-12-2008, 12:09 PM   #4
ProfMoriarty
CF Senior Member
Quote:
Thanks, but what the hell good is this guy gonna do me?
Old 12-12-2008, 12:11 PM   #5
MTVette
CF Senior Member
MTVette's Avatar
Quote:
Originally Posted by Umrswimr View Post
An electrician.
Rather than using a transformer, just re-do the circuit breaker panel to connect the line to a 110 position on the panel and put in a different outlet in the workshop.
MTVette is offline   Reply With Quote
Old 12-12-2008, 12:13 PM   #6
ProfMoriarty
CF Senior Member
Quote:
How would I do that?
Install a 110V20A breaker into an empty slot and install a new outlet?
The current outlet is 3 wire 12 ga.
Old 12-12-2008, 12:13 PM   #7
jfb
CF Senior Member
I agree, you can even use the same wires that are in place! All you need is a 20 amp breaker and a new outlet. You will probably have to run a ground wire to the outlet.
jfb is online now   Reply With Quote
Old 12-12-2008, 12:16 PM   #8
1Patriot
CF Senior Member
1Patriot's Avatar
Is the current outlet 3 or 4 wire? You may be able to retag the wires and change the connections at each end.
1Patriot is online now   Reply With Quote
Old 12-12-2008, 12:18 PM   #9
mardyn
CF Senior Member
mardyn's Avatar
I've got a similar situation over in my equipment barn. I simply installed another box/outlet adjacent to the 220V plug, and used one side of the 110 line + the neutral and ground wires to the the 110 outlet... simple and took about 15 minutes to complete, plus I still have the 220V plug to run the air compressor or welder.
but, be freakin' careful when screwing with the installation... turn of the damn 220V breaker before even thinking about getting started.
Good Luck
mardyn
mardyn is offline   Reply With Quote
Old 12-12-2008, 12:19 PM   #10
N8sFavToy
CF Senior Member
N8sFavToy's Avatar
Send a message via AIM to N8sFavToy
That's a top-of-the-line transformer. Step down transformer would be like Bumble Bee.
N8sFavToy is offline   Reply With Quote
Old 12-12-2008, 12:20 PM   #11
utah997
Circles are Hard
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
utah997's Avatar
An electrician.
Roger that.
utah997 is offline   Reply With Quote
Old 12-12-2008, 12:22 PM   #12
ProfMoriarty
CF Senior Member
Quote:
Originally Posted by utah997 View Post
Roger that.
Who is this Roger the electrician of whom you speak?
Old 12-12-2008, 12:22 PM   #13
ProfMoriarty
CF Senior Member
dbl tap
Old 12-12-2008, 12:24 PM   #14
jfb
CF Senior Member
Can't your read? The electricians name is Roger That!
Old 12-12-2008, 12:24 PM   #15
00Nassau
CF Senior Member
St. Jude Donor '11
00Nassau's Avatar
You might want to look at this website to understand what is currently there:
http://220outlet.com/
00Nassau is offline   Reply With Quote
Old 12-12-2008, 12:25 PM   #16
Z064life
CF Senior Member
St. Jude Donor '06
Z064life's Avatar
please post a pic of the outlet...it is really easy if you have single phase 220, if you have dual phase you will have an extra wire, but that can be dealt with easily.
Z064life is offline   Reply With Quote
Old 12-12-2008, 12:28 PM   #17
ProfMoriarty
CF Senior Member
Good Luck
mardyn
IIRC, 220V service has 2 hot wires which would test at 110V each.
But this is where I get confoozled. I can see using one of the hot wires, a neutral, and ground to a separate 110V outlet, but I don't see how that would allow the 220 line to remain active if the neutral and ground have been utilized to wire the 110V outlet.
Old 12-12-2008, 12:28 PM   #18
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
C5Nate's Avatar
Good Luck
mardyn
Thats a fire or death waiting to happen.
Your original 220 breakers are joined together, you could have a big problems if one lag blows and the other doesn’t.
C5Nate is offline   Reply With Quote
Old 12-12-2008, 12:28 PM   #19
Indy-hp
CF Senior Member
St. Jude Donor '09
Indy-hp's Avatar
Yes. The three wires are two 110V positives (usually red and black wires) and one neutral (usually white). Reconnect the black wire to a new 110V breaker in the breaker box, disconnect the red wire altogether, and replace the outlet with a standard 110V using the black and white wires, again leaving the red disconnected. If there is a fourth, bare wire, that is a ground and can be reused as a ground.
Indy-hp is offline   Reply With Quote
Old 12-12-2008, 12:29 PM   #20
ProfMoriarty
CF Senior Member
Quote:
The pic of the outlet is in the first post.
Reload this Page How to convert 250V 20A outlet to 110V 20A?
Tags
110v, 20, 20a, 220v, 250, 250v, amp, change, connection, convert, converter, outlet, plug, step, wire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
