Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-22-2008, 11:32 PM   #1
Aggravated4life
CF Senior Member
Cruise-In II Veteran
Aggravated4life's Avatar
Default What Causes a Pushrod/Rocker Arm To Become Loose?
My neighbor built a 460 chevy big block and has it running.I was going to take pics and a video,but lo and behold one of the rocker arms went sideways and the pushrod got damaged,rubbing up against the guide.
He replaced the pushrod and readjusted the valve lash with motor running and etc.That same rocker arm seems to want to come loose or move sideways again.
Hes the mechanic so Im sure he will figure it out,but I was curious as well to what can cause this to happen on just one area?The others are fine and working great.
The heads,engine had full machine work done by a shop he uses,yet he put the entire engine components back together himself.Hes built many motors at home and never had this happened before either.
Im very curious to what can cause this problem on a big block or any chevy engine for that matter.He has a comp cam,springs, rocker arms and/or the matched comp valve train set for his particular build.
Any ideas or links is appreciated.Im just very curious to know what might be a common cause.
Thanks!
Aggravated4life is offline   Reply With Quote
Old 06-23-2008, 01:03 AM   #2
steves65korvette
CF Senior Member
steves65korvette's Avatar
Boss where rocker arm stud is installed may be busted,,,letting stud pull out. Rocker arm boss should be milled and screw in studs installed for a HP application. If running hydraulic lifters, it may be bad and leaking down. Although I think it would have to leak off really quick to allow the rocker to jump off like that. Just a couple of possibilities. Steve
steves65korvette is offline   Reply With Quote
Old 06-23-2008, 01:12 AM   #3
cdg2000c5
CF Senior Member
St. Jude Donor '08
cdg2000c5's Avatar
i followed that first thread and requested a vid.. i hope he gets it worked out
cdg2000c5 is offline   Reply With Quote
Old 06-23-2008, 01:16 AM   #4
Aggravated4life
CF Senior Member
Quote:
Thanks Steve...
From what I can gather,he removed the stud and checked it for damage.Did not see any damage inside the boss itself.
( may need another closer look)
Didnt appear to be any.Rocker arm itself was not damaged.Just the pushrod got damaged by rubbing the guide plate.
He put it back together and installed a new pushrod and did the adjustments again.
The rocker arm doesnt just slip off but if you tap it with a socket,while the engine is running,it will go off sideways.It originally slipped off on its own.
None of the other studs or rocker arms or push rods do this.I wonder if there ca be a crack inside the boss that one cant see by simply looking at it.The stud does seat and torque to specs.THis is gonna be interesting.
Thanks again.
Old 06-23-2008, 01:21 AM   #5
Aggravated4life
CF Senior Member
Quote:
Me too...I wanted to take pics and a vid and this happened.Hope its nothing too serious.He was a bit pissed off today when trying to diagnose wtf was going on but is gonna have to put it on hold since he has to work all week,but hope he gets it fixed soon.If theres a problem in the head,lifter,or the spring seat that would suck,but im not sure what will come of it.
Will keep ya all posted...im excited for him yet same time undy his frustration right now.Just never seen it happened before.
Old 06-23-2008, 02:50 AM   #6
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
Support Corvetteforum!
C5Nate's Avatar
Some rocker arm studs are pressed into the head, not screwed in. It may just be backing out.
There are procedures to fix this like pinning the stud through the boss.
Does he have poly locks or lockable nuts on the studs?
If not, just replacing the nut may solve the problem.
OR
Do like we did back in the old days when money was tight, we just whacked the nut with a hammer to slightly warp the hole making for a tight fit that didnít back off.
C5Nate is offline   Reply With Quote
Old 06-23-2008, 03:25 AM   #7
Mirroredshades
CF Senior Member
Mirroredshades's Avatar
Uuuuuuhhhhhhhhhhhhhhhh. Vibration?
Mirroredshades is offline   Reply With Quote
Old 06-23-2008, 03:49 AM   #8
65Z01
CF Senior Member
65Z01's Avatar
Send a message via AIM to 65Z01
Try swapping that rocker arm & stud with a set from another location to see if the problem goes with the set of stays with that location.
If the problem moves with the pair, then move just the rocker arm.
__________________
My 1988 Z01 #65 Site
65Z01 is offline   Reply With Quote
Old 06-26-2008, 12:19 AM   #9
Aggravated4life
CF Senior Member
Thanks for all the suggestions...I spoke with my neighbor and he spoke with the engine machinist that did the machine work.He was told to use roller rocker arms,or roller tips and hardened pushrods,since the cam he used can cause this problem with the stuff hes running now.
Hes going to try this route and see if the engine machinist is right...so far there are no other mechanical problems found.
I do like the idea of switching and see if it moves.I'll suggest that to him as well as advice off here.
But as I said,they believe the problem is with the new cam and springs,and the stamped rocker arms- pushrods need to be replaced.
We shall see this week how it goes.
Old 06-26-2008, 12:32 AM   #10
blown87
CF Senior Member
GA Events Coordinator
blown87's Avatar
I am going to go out on a limb here, but I have been up this tree more than a few times with a BBC.
If he is running a big cam with a lot of spring pressure and does not use the proper break-in and do a proper warm up EVERY time he starts the motor he may have done what I have done more times than I want to remember.
If the stud is not coming out and the nut is not coming loose that only leaves a lobe going away.
BTDT.
blown87 is offline   Reply With Quote
Old 06-26-2008, 12:36 AM   #11
Aggravated4life
CF Senior Member
BTDT.
That sounds like good advice...Im going to pass that along.Yeah they are saying they believe its the bigger cam and spring pressure along with stock rocker arms and non hardened push rods that may be the culprit,but more info like yours always helps.
Reload this Page What Causes a Pushrod/Rocker Arm To Become Loose?
Tags
arm, arms, bbc, coming, engine, jump, lobe, loose, motor, push, pushrod, pushrods, rocker, rod, tight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
