Corvette Forum
Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-28-2008, 03:33 PM   #1
NitrousSam
CF Senior Member
Support Corvetteforum!
NitrousSam's Avatar
sammillersells sammillersells
Default Largest Small Block Chevy Engine (aftermarket)
What is the largest aftermarket small block Chevy engine? I know there are some in the lower 500 cubic inch arena being built by Sonny Leonard. Anyone know of anything any larger?
NitrousSam is offline   Reply With Quote
Old 04-28-2008, 03:40 PM   #2
comp
CF Senior Member
comp's Avatar
ah ,,,,,, small block over 500ci ???
comp is offline   Reply With Quote
Old 04-28-2008, 03:41 PM   #3
thkauffman
CF Senior Member
thkauffman's Avatar
Location: It is a tale told by an idiot, full of sound and fury, signifying nothing. Alto MI
Katech is currently taking orders for a 500 cube engine. Don't know if it's a small block or not.
thkauffman is offline   Reply With Quote
Old 04-28-2008, 03:43 PM   #4
LordVader
CF Senior Member
LordVader's Avatar
I *think* GM Performance Parts offers an LSX engine that is 500+ cubes...
Hard to imagine but they're doing it...
LordVader is offline   Reply With Quote
Old 04-28-2008, 03:45 PM   #5
smearig
CF Senior Member
smearig's Avatar
Quote:
smearig is offline   Reply With Quote
Old 04-28-2008, 03:48 PM   #6
TPFKATK
CF Senior Member
TPFKATK's Avatar
http://video.google.com/videoplay?do...73746437283390
TPFKATK is offline   Reply With Quote
Old 04-28-2008, 03:48 PM   #7
lite blue
CF Senior Member
lite blue's Avatar
Location: I was a lonely, teenage broncin' buck, with a pink carnation and a pickup truck
Wiki says 454. Doesn't mean it's right, of course.
lite blue is offline   Reply With Quote
Old 04-28-2008, 03:49 PM   #8
juiced
CF Senior Member
juiced's Avatar
Send a message via AIM to juiced
454 is really the largest you should go.
Since most after market blocks are 4.155 or 4.190 max bore you would need a tall deck block and a 4.5" crank. The motor would be a ticking time bomb with 0 room for error and if something does go wrong it wont have enough material to be fixed.
The motor would have to be NA as the pistons would not have enough meat on the to support a decent compression height or ring pack, the oil ring would be in the pin boss are and the cylinder wall loading would be ridiculous.
juiced is offline   Reply With Quote
Old 04-28-2008, 03:49 PM   #9
smearig
CF Senior Member
smearig's Avatar
Quote:
That's wrong, 454 c.i. small blocks are old hat at this point.
Old 04-28-2008, 03:50 PM   #10
LordVader
CF Senior Member
LordVader's Avatar
Quote:
Originally Posted by TPFKATK View Post
Damn...
Old 04-28-2008, 03:50 PM   #11
chaase
CF Senior Member
chaase's Avatar
The LS7 is a small block, so 454 wouldn't be too far off. It comes down to block strength and how much you can over bore it.
chaase is offline   Reply With Quote
Old 04-28-2008, 03:51 PM   #12
juiced
CF Senior Member
juiced's Avatar
Quote:
the LSX family of engines has a much taller deck than a SBC so you can use a longer rod and with the DART Bilet block or the Warhawk block you can get real close to 500ci. the main reason for ths is that the motors can go to 4.250 bores so you don't need a ridiculous long stroke.
Old 04-28-2008, 03:53 PM   #13
McLovin'
CF Senior Member
McLovin''s Avatar
I *believe* the LSX can be taken to 482ci
the Warhawk tall-deck block can go a bit higher but their site suggests 454ci
McLovin' is offline   Reply With Quote
Old 04-28-2008, 03:58 PM   #14
93Polo
CF Senior Member
CI 3-4-5-9 Veteran
93Polo's Avatar
Send a message via AIM to 93Polo
Quote:
Sonny Leonard built 500"+ small blocks back in '94
http://www.sonnysracing.com/about.php
93Polo is offline   Reply With Quote
Old 04-28-2008, 03:59 PM   #15
93Polo
CF Senior Member
CI 3-4-5-9 Veteran
93Polo's Avatar
Quote:
and I don't consider the LSX Gen III/IV motor to be a SBC.
Old 04-28-2008, 04:04 PM   #16
LordVader
CF Senior Member
LordVader's Avatar
Quote:
In the traditional sense, it's not but it IS the "small block" of today
What would you consider it then?
Old 04-28-2008, 04:05 PM   #17
EG@EnglandGreen
Supporting Tuner
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ ____________ 281.464.2800
englandgreen.corp englandgreen
Send a message via ICQ to EG@EnglandGreen Send a message via AIM to EG@EnglandGreen
Officially - the LS family are Generation III & Generation IV small block Chevy engines - although they share zero parts with the Generation II SBC. Generation II SBC is the traditional water cooled intake manifold/rear mount distributor that we know and love.
The Warhawk is currently the largest LS/SBC at 481ci
Stephen
Last edited by EG@EnglandGreen; 04-28-2008 at 04:59 PM. Reason: Thinking of Ford Cleveland and Windsor V8s...
EG@EnglandGreen is offline   Reply With Quote
Old 04-28-2008, 04:06 PM   #18
smearig
CF Senior Member
smearig's Avatar
Technology, pfft.
Old 04-28-2008, 04:07 PM   #19
Doug28450
CF Senior Member
Doug28450's Avatar
What good are you?
Doug28450 is offline   Reply With Quote
Old 04-28-2008, 04:08 PM   #20
EG@EnglandGreen
Supporting Tuner
Quote:
Originally Posted by Doug28450 View Post
What good are you?
He's Tim, the Enchanter!!!!
Reload this Page Largest Small Block Chevy Engine (aftermarket)
Tags
472, 500, 500ci, biggest, block, chevy, ci, cubic, engine, engines, gm, largest, racing, small, sonny
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
302's ZD75blue C3 Tech/Performance 48 12-16-2002 03:26 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
