Corvette Forum
Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-04-2008, 10:53 PM   #1
2000BSME
CF Senior Member
2000BSME's Avatar
Default Need help fixing Plaster Mold of my trunk lid please[pictures].
Hey, I've made a plaster mold of my trunk for my c5 vert, I have plans to make a carbon fiber/fiberglass layup that I can use for racing needs in the next season....
Anyway, my problem is a few imperfections. For one, I need to fill in the emblem, as I don't want that to be in my layup, and a few pothole/rough spots that are less than desireable.
Do I need to dig up some of the rough spots and then add more material? Or should I just put spot filler on it? Or will some really thick gelcoats be enough to fill it in?
Advice appreciated. In retrospect, I should've mixed the stuff up better, and this might not have happened, but so far, a lot of time effort and money has gotten me this far, and I'd rather not start all over.
The vast majority of the surface is glossy smooth, but there's about 10% that needs some touch up work.
Thanks, and here's some pics of the framing that I made to start this project:
2000BSME is offline   Reply With Quote
Old 01-04-2008, 11:04 PM   #2
Grease Monkey
CF Senior Member
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Grease Monkey's Avatar
Location: Hampton, VA Yea, i'm a redneck... but you love it
Send a message via AIM to Grease Monkey
mix up a bit more, force it in the spots, flatten out
__________________
-Doug
Grease Monkey is offline   Reply With Quote
Old 01-04-2008, 11:09 PM   #3
2000BSME
CF Senior Member
2000BSME's Avatar
Quote:
thanks, you make it sound like it won't be any biggie!?
Old 01-04-2008, 11:11 PM   #4
Grease Monkey
CF Senior Member
Quote:
Ever mud up drywall? Same thing basically. Shouldn't be a problem. Just get a long enough flat blade to span past each side of the imperfection so that it is even when you flatten it. And get all the air out or else when it dries it may sink a bit.
Old 01-04-2008, 11:19 PM   #5
Petew1971
CF Senior Member
Petew1971's Avatar
Take hammer bash out of frame..mix better, do over..if youre gonna do something do it right
Petew1971 is offline   Reply With Quote
Old 01-04-2008, 11:22 PM   #6
MrSpeedyBob
CF Senior Member
MrSpeedyBob's Avatar
Send a message via AIM to MrSpeedyBob
It's hard to believe there isn't an aftermarket carbon fiber trunk lid available for a corvette. Did you undertake this project for the satisfaction of doing it yourself, or is this really something the aftermarket hasn't produced?
MrSpeedyBob is offline   Reply With Quote
Old 01-04-2008, 11:38 PM   #7
OutKlast
CF Senior Member
OutKlast's Avatar
Quote:
Why is it that hard to believe? Probably wouldn't be as popular as something like a hood that holds a much more prominent position.
OutKlast is offline   Reply With Quote
Old 01-04-2008, 11:43 PM   #8
comp
CF Senior Member
comp's Avatar
comp is offline   Reply With Quote
Old 01-04-2008, 11:49 PM   #9
CGGorman
CF Senior Member
CGGorman's Avatar
Mix up a cup of plaster, spray the hardened stuff with water to dampen, spread new with fingers to fill voids, leave slightly raised above hardened area. Once dry, sand smooth.
CGGorman is offline   Reply With Quote
Old 01-04-2008, 11:55 PM   #10
2000BSME
CF Senior Member
2000BSME's Avatar
I haven't exhausted my searching measures on the project, but I haven't found one yet. Please link me if you have one, and I'll write off the $150 I have invested so far.
Old 01-04-2008, 11:57 PM   #11
comp
CF Senior Member
comp's Avatar
you find any forum's for this DIY ???
Old 01-05-2008, 12:02 AM   #12
2000BSME
CF Senior Member
2000BSME's Avatar
Quote:
I did all my research on Youtube and Google. Watched a bunch of videos on fiberglass/carbon fiber, and just a little bit of plaster mold making. I haven't come across a video for repairing imperfections in deck lids.
Old 01-05-2008, 12:03 AM   #13
comp
CF Senior Member
comp's Avatar
thanks
Old 01-05-2008, 12:04 AM   #14
Petew1971
CF Senior Member
Petew1971's Avatar
You almost nailed it the first time around but not quite. Use that as a learning experience and knock out a perfect cast like a true craftsman. I cant imagine plaster costing that much and if it turns out sweet then maybe you could sell a few of these suckers.
Old 01-05-2008, 12:07 AM   #15
JPS2345
CF Senior Member
JPS2345's Avatar
Send a message via AIM to JPS2345 Send a message via MSN to JPS2345 Send a message via Yahoo to JPS2345
I know a guy from my s-10 forum, who is a fiberglass/CF master..ill see if i cant get you his info, hes usually pretty willing to help out with info
JPS2345 is offline   Reply With Quote
Old 01-05-2008, 12:09 AM   #16
2000BSME
CF Senior Member
2000BSME's Avatar
Quote:
Imagine it costing this much: $15/bag, at 4 bags, $60 bucks and a bunch of mixing spreading, frame making, not to mention lifting that heavy sob and turning it over...
I'm gonna stay the course on this one. I am a man of utility, not a waxer by any means...
Old 01-05-2008, 12:10 AM   #17
2000BSME
CF Senior Member
2000BSME's Avatar
Quote:
wow, I'd appreciate that... Thanks
Old 01-05-2008, 12:22 AM   #18
JPS2345
CF Senior Member
JPS2345's Avatar
I sent him a PM dont know if you will get a reply or not, I dont have his email and if i did, wouldnt want to without his consent.. I sent him a link to this page, Ive seen his glass work...its exceptional to say the least.
I dont know if its worth your time to sign up over there and send him a PM or not, but its on S10forum.com and his screen name is NickZigaitis
here is a link to his glassing How-to http://www.s10forum.com/forum/f26/te...nd-two-208071/
Old 01-05-2008, 12:36 AM   #19
2000BSME
CF Senior Member
2000BSME's Avatar
thanks, that's a ton of material to look over.
Old 01-05-2008, 03:10 AM   #20
cuisinartvette
CF Senior Member
St. Jude Donor '05
Maybe Wren could give you some input, he seems pretty sharp about this type of stuff. Hopefully he pipes in. Always wished I could learn how to mold parts. Keep at it!!
cuisinartvette is online now   Reply With Quote
Reload this Page Need help fixing Plaster Mold of my trunk lid please[pictures].
Tags
c5, carbon, fiber, lid, making, mold, mould, plaster, sound, trunk, youtubefixing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
