Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-26-2007, 05:55 PM   #1
chuckster
CF Senior Member
chuckster's Avatar
Send a message via AIM to chuckster
Default Replacing a front Wheel Bearing/Hub on my 2001 Tahoe this weekend.. Need Info
It's a 2 wheel drive Tahoe. Grinding sound from drivers side, increases with speed.. not the brakes.
What I need is the Bolt sizes so Imake sure I have the right tools...
There are 3 bolts that hold it to the spindle..What other extra large size bolts do I need to be aware of? What size and type are they? Any gotchas or just straight forward?
chuckster is offline   Reply With Quote
Old 09-26-2007, 06:18 PM   #2
ddecart
CF Senior Member
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
ddecart's Avatar
Bolt sizes or socket sizes?
10, 13, 15, 18, 19, 21 (or 13/16)mm sockets will take off just about everything on a GM car.
ddecart is offline   Reply With Quote
Old 09-26-2007, 06:41 PM   #3
chuckster
CF Senior Member
chuckster's Avatar
Someone on a tahoe forum mentioned something large like 1 3/4" But I think they may have been referring to the hub nut only found on the 4 wheel drive model..
Old 09-26-2007, 06:44 PM   #4
Entropy
CF Senior Member
St. Jude Donor '08-'09
Entropy's Avatar
Quote:
Yeah it's either that or something like 32,34 or 36 mm (I can't remember).
I've never done a hub replacement on a 2WD model. Not too many of those in the snow states.
Entropy is offline   Reply With Quote
Old 09-26-2007, 06:44 PM   #5
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
Support Corvetteforum!
C5Nate's Avatar
Are you positive its not the little wear indicator on your brake pads.
The noise they make is very similar.
C5Nate is offline   Reply With Quote
Old 09-26-2007, 06:51 PM   #6
chuckster
CF Senior Member
chuckster's Avatar
Postitive.. It's a very similar feel and sound to when a brake pad is totally gone and its metal on metal grinding sound..
Like Cshhhhhh..Cshhhhhh...Cshhhhhh...Cshhhhhh that gets faster as I drive and slower when I slow down.. BUT... NO change in sound hitting the brakes..and gets worse turning.. I wish it were the pads...
Old 09-26-2007, 06:52 PM   #7
chuckster
CF Senior Member
chuckster's Avatar
Luckily I am only 2 wheel drive.. no worries..
Old 09-26-2007, 07:35 PM   #8
jack_squat
CF Senior Member
jack_squat's Avatar
You'll need a 5mm allen socket to remove the ABS sensor from the hub unless you have a new bearing cartridge that includes the sensor and pigtail. Some come with it (Genuine GM), some don't.
jack_squat is offline   Reply With Quote
Old 09-26-2007, 08:06 PM   #9
jcswm
CF Senior Member
jcswm's Avatar
if its louder on a left turn.... it's the right side hub
if its louder on a right turn.... it's the left side hub
2wd is very easy... one Beer job.... 2 beers if you take your time!!
jcswm is offline   Reply With Quote
Old 09-26-2007, 10:34 PM   #10
chuckster
CF Senior Member
chuckster's Avatar
Just jacked up each side tonight.. Its the driver side...
If I shake the wheel from top and bottom.. It's loose... and spins noisily..
The Passenger side is tight and smooth...
Looks like I know what I will be doing Saturday...
Old 09-26-2007, 10:48 PM   #11
jcswm
CF Senior Member
jcswm's Avatar
WOW.... your lucky!!! they've come WAY down in price
Advance and Discount both have them under $150.00
last one I did was over $400.00!!!
Old 09-26-2007, 10:54 PM   #12
AZ Z51
CF Senior Member
St. Jude Donor '05
AZ Z51's Avatar
Send a message via ICQ to AZ Z51 Send a message via AIM to AZ Z51
I know some of those are bolted in with a negative torx socket
AZ Z51 is offline   Reply With Quote
Old 09-26-2007, 11:23 PM   #13
chuckster
CF Senior Member
chuckster's Avatar
Autozone... $144!!!
Old 09-26-2007, 11:24 PM   #14
chuckster
CF Senior Member
chuckster's Avatar
Quote:
That is what my original post is about. I dont want to get a surprise.. I am pretty sure the calipers have a huge torx bolt but not sure about the Spindle..
Old 09-27-2007, 11:35 AM   #15
jack_squat
CF Senior Member
jack_squat's Avatar
Calipers have a T55 TORX. You'll need a BIG breaker bar for them and the caliper bracket bolts. They're put on by Superman at the factory.
Old 09-28-2007, 08:57 AM   #16
AZ Z51
CF Senior Member
St. Jude Donor '05
AZ Z51's Avatar
you should be able to look at the back side of the spindle and see whats holding in the bearing with out taking it all apart.
Old 09-28-2007, 09:09 AM   #17
steck
CF Senior Member
steck's Avatar
yup, i paid a fortune too on my 2001 yukon. came as a whole 'assembly'.
it was causing my ABS to engage all the time as i came to a stop !!
cant help ya on the nut sizes....mechanic did it for me
steck is offline   Reply With Quote
Old 09-28-2007, 09:18 AM   #18
Son93SL2
CF Senior Member
Son93SL2's Avatar
I've never seen a 1 3/4" bolt on a regular car, a coal strip mining dump truck yes, Tahoe, no.
__________________
i2iSTUDIOS.com
Son Ton, Cincinnati Photographer, Wedding, Glamor, Fashion,Models, Senior Pictures, Family Portraits
i2iSTUDIOS.com/journal/
Son Ton, Cincinnati, Ohio Photographer Wedding, Glamour, Fashion,Models, Senior Pictures, Family Portraits, blog
Son93SL2 is offline   Reply With Quote
Old 09-28-2007, 09:36 AM   #19
AZ Z51
CF Senior Member
St. Jude Donor '05
AZ Z51's Avatar
Quote:
the axel nut is pretty damn big
Old 09-28-2007, 10:13 AM   #20
scottycards
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13
scottycards's Avatar
Just a guess- is this thing a Unit Bearing? Three ~1/2" (or metric equiv) twelve point bolts that hold it on to the knuckle?
If so, pull caliper, 36mm socket for spindle, pull spindle, then the three 12 pt bolts for unit bearing, then BFH to remove unit bearing, reverse to replace.
If it's not a unit bearing, forget everything I just typed........
scottycards is offline   Reply With Quote
Reload this Page Replacing a front Wheel Bearing/Hub on my 2001 Tahoe this weekend.. Need Info
Tags
2001, 2002, 2007, bearing, front, hub, remove, replace, size, sizes, socket, tahoe, torque, wheel, wrench
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
