Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
View Poll Results: Pumping; is it bad?
Won't hurt the car 12 41.38%
DON'T DO IT! 17 58.62%
Voters: 29. You may not vote on this poll
Old 05-12-2007, 12:00 AM   #1
Lord Odin
CF Senior Member
Lord Odin's Avatar
Send a message via MSN to Lord Odin
Default Pumping gas pedal when starting car w/ fuel injection
I have heard that pumping the gas pedal when a car that has fuel injection and is having trouble starting is bad for the car. No explanation as to why but only that it is bad and fuel injection should handle the problem by itself, unlike vehicles with carburetors. What is so bad about pumping the gas?
If the injectors are getting clogged, wouldn't pumping the pedal actually help it in that circumstance?
Lord Odin is offline   Reply With Quote
Old 05-12-2007, 12:08 AM   #2
CGGorman
CF Senior Member
CGGorman's Avatar
In some case, the ECU will shut down the injectors if you WOT during cranking. This is a routine inserted to help clear a flooded engine.
Oherwise, I don't know a reason why pumping would help OR hurt.
CGGorman is offline   Reply With Quote
Old 05-12-2007, 12:16 AM   #3
CGGorman
CF Senior Member
CGGorman's Avatar
Injectors are basically just electric switches. They either spray or not, depending on te presence of electrical current. The only real variable with a given injector is how long the "switch" is allowed to remain off or on. The throttle in most EFI car until very recently was electromechanical. Mech. in that it opened and closed the throttle blades just like on a carb. Electrical in that there is a sensor mounted on the throttle butterfly shaft that tells the computer how far open the throttle is. The computer uses that info, plus more info from various other sensors (air flow, air temp, crank position+RPM, etc.) to determine how to switch the injectors.
Pumping the throttle is useless in a EFI engine. If it won't start, there is a real problem somewhere.
On a carbureted engine, your foot controls a helluva lot more, such as the choke position and enrichment (squirt of raw fuel for each press of the pedal). The fuel delivery is "dumb". It relies completely upon engine vacuum or your foot (or both) to get fuel out of the fuel bowl.
A cold engine needs a richer mixture to start and run smoothly. On EFI cars, that is handled by the computers. On Carb'd engines, it's the choke. Most people don't have a freakin' clue how to tune a carb to run when the engine is warm, let alone when it's cold or during the transition between the two. Often, that means not enough fuel during cold start, so pumping the throttle will squort a bunch extra in there. It will just lay in the intake for a bit, but it;s enough to get the car running.
Old 05-12-2007, 12:20 AM   #4
vttedrm
CF Senior Member
vttedrm's Avatar
My answer is Both. It won't really hurt the car (may flood) but I don't do it.
vttedrm is offline   Reply With Quote
Old 05-12-2007, 12:20 AM   #5
Fastbird
Former Sponsor
Fastbird's Avatar
Send a message via AIM to Fastbird
Exactly. There's no point to pump the pedal on a fuel injected car UNLESS you know the engine is flooded and you need to clear out the cylinders. Even in that case you simply hold the pedal to the floor until the car starts.
Fastbird is offline   Reply With Quote
Old 05-12-2007, 12:31 AM   #6
gpracer1
CF Senior Member
gpracer1's Avatar
Quote:
Most injected cars have a "clear flood mode". If you hold the pedal down all the way and then crank the car, the injectors do not squirt fuel.
gpracer1 is offline   Reply With Quote
Old 05-12-2007, 12:32 AM   #7
scorp508
CF Senior Member
scorp508's Avatar
C4s put you into a flood clear mode and don't fire the injectors with the pedal at WOT during cranking.
scorp508 is offline   Reply With Quote
Old 05-12-2007, 12:36 AM   #8
comp
CF Senior Member
comp's Avatar
best to try to start 3 times (short cranks) No start smell for fuel,,,turn key on press one time then crank
comp is offline   Reply With Quote
Old 05-12-2007, 01:56 AM   #9
Buffalo Dude
CF Senior Member
St. Jude Donor '07
Buffalo Dude's Avatar
Send a message via AIM to Buffalo Dude
What he said.
Buffalo Dude is offline   Reply With Quote
Old 05-12-2007, 07:46 AM   #10
Lord Odin
CF Senior Member
Lord Odin's Avatar
So there is no possible way of pumping the gas pedal to hurt the car with EFI?
Old 05-12-2007, 07:56 AM   #11
Torqaholic
CF Senior Member
St. Jude Donor '09
Torqaholic's Avatar
If you're wanting to pump the pedal due to problems starting a cold vehicle try turning the key to the on position and waiting a few seconds for the fuel pump to pressurize the system before cranking it over.
Torqaholic is offline   Reply With Quote
Old 05-12-2007, 08:34 AM   #12
Tom/99
CF Senior Member
Tom/99's Avatar
You don't need to touch the gas pedal when starting a fuel injected car.
Tom/99 is offline   Reply With Quote
Old 05-12-2007, 09:27 AM   #13
Muffin
CF Senior Member
Muffin's Avatar
What CGGorman said with one small addition:On a MAF car the ECM, through the TPS, reads not only how far the throttle plates are open but also the rate at which the opening is changing. If you pump the gas pedal while the car is starting the ECM can, in a sense,become confused.
Muffin is offline   Reply With Quote
Reload this Page Pumping gas pedal when starting car w/ fuel injection
Tags
bad, car, efi, fuel, gas, injected, injection, pedal, press, problems, pump, pumping, start, starting, touch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
