Go Back   Corvette Forum > Off Topic > Off Topic
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Off Topic
Off Topic | Non-Corvette Sponsored by
Bondurant School of HPD
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-02-2007, 06:07 PM   #1
1K SPORT
CF Senior Member
1K SPORT's Avatar
Default What is the best way to cut a pad lock?
I need to cut a master lock off and was wondering if bolt cutters or a cutting wheel would be better? I will need to buy whatever one will work better.
It's a Master combo pad lock. The Shackle is 9/32".
This is a serious issue, I can't get to my beer!
Thanks.
1K SPORT is online now   Reply With Quote
Old 04-02-2007, 06:10 PM   #2
00Nassau
CF Senior Member
St. Jude Donor '11
00Nassau's Avatar
You might try just taking a hammer to it if what it is connected to will take the force. I have opened a couple of locks in the past that way.
00Nassau is offline   Reply With Quote
Old 04-02-2007, 06:11 PM   #3
Rapid Roger
CF Senior Member
Rapid Roger's Avatar
Send a message via AIM to Rapid Roger
if you are going to buy something....Go with an angle grinder...You will find many other uses where bolt cutters aren't used that often......
Rapid Roger is offline   Reply With Quote
Old 04-02-2007, 06:11 PM   #4
Aflac
CF Senior Member
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Aflac's Avatar
Send a message via Yahoo to Aflac
either bolt cutters or cut the hasp...
Aflac is offline   Reply With Quote
Old 04-02-2007, 06:16 PM   #5
Gipper
CF Senior Member
St. Jude Donor '12
Gipper's Avatar
bolt cutters. Wear safety glasses and snap em like buttah!
Gipper is offline   Reply With Quote
Old 04-02-2007, 06:20 PM   #6
fatboytc88
CF Senior Member
roto zip tool. use a grinding wheel per application. - metal cutting wheel.
fatboytc88 is offline   Reply With Quote
Old 04-02-2007, 06:20 PM   #7
TPFKATK
CF Senior Member
Support Corvetteforum!
TPFKATK's Avatar
I gotta go with the angle grinder.
Or .308 Win.
TPFKATK is offline   Reply With Quote
Old 04-02-2007, 06:20 PM   #8
Diego M
CF Senior Member
Diego M's Avatar
Grinder, acetylene torch, or bolt cutters. whichever one you can get to first
Diego M is offline   Reply With Quote
Old 04-02-2007, 06:26 PM   #9
tumbleweed
CF Senior Member
tumbleweed's Avatar
Location: "There's a he11 of a lot of things they didn't tell me when I signed on this outfit....... i'm practicing to be a grouchy old man, and getting good at it....
I would go with the grinder if you need to cutthe lock.....but as someone else said, sometimes it's easier to cut the hasp.....
tumbleweed is offline   Reply With Quote
Old 04-02-2007, 06:32 PM   #10
grapeknutz
CF Senior Member
St. Jude Donor '06
A pound of thermite will do!
grapeknutz is offline   Reply With Quote
Old 04-02-2007, 06:33 PM   #11
383_Proof
CF Senior Member
383_Proof's Avatar
Quote:
+10000
I used a dremel to do the exact same thing this past weekend....took about 2 minutes to cut through...
383_Proof is offline   Reply With Quote
Old 04-02-2007, 06:34 PM   #12
boracayjohnny
CF Senior Member
boracayjohnny's Avatar
Location: You should have told him it would not hit 185 if you dropped it out of the back of a C130 with 4 heffalumps inside trying to get to the Golden Corral.
Send a message via Yahoo to boracayjohnny
Quote:
Originally Posted by TPFKATK View Post
Or .308 Win.
I like the way you're thankin'.
Also, you could go with a D-9 Caterpillar or 10 sticks of dynamite.
boracayjohnny is offline   Reply With Quote
Old 04-02-2007, 06:36 PM   #13
jfb
CF Senior Member
Small bolt cutters may not do the job (too much effort), but a bolt cutter will go through a Master lock! I've done it.
jfb is offline   Reply With Quote
Old 04-02-2007, 06:36 PM   #14
1K SPORT
CF Senior Member
1K SPORT's Avatar
There is no hasp.
The lock has a long shackle. It is on a side by side refrigerator around the door handles.
Thanks for the suggestions. A grinder looks like it could be fun...
Old 04-02-2007, 06:37 PM   #15
scorp508
CF Senior Member
scorp508's Avatar
Or .308 Win.
Not according to Mythbusters!
scorp508 is offline   Reply With Quote
Old 04-02-2007, 06:38 PM   #16
1K SPORT
CF Senior Member
1K SPORT's Avatar
Are the biggest bolt cutters 24"?
Old 04-02-2007, 06:38 PM   #17
PRNDL
CF Senile Member
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
Why don't you just ask Mommy nicely for the key?
PRNDL is offline   Reply With Quote
Old 04-02-2007, 06:40 PM   #18
SteveR.
CF Senior Member
SteveR.'s Avatar
Send a message via ICQ to SteveR.
A Dremel or hammer will work.
SteveR. is offline   Reply With Quote
Old 04-02-2007, 06:40 PM   #19
Torqaholic
CF Senior Member
St. Jude Donor '09
Torqaholic's Avatar
44mag with 300gr XTP works and is fun too. Wasn't a combination lock though, it was keyed and had a short shank. Bullet placement on the top pushed it apart on the first try.
Torqaholic is offline   Reply With Quote
Old 04-02-2007, 06:41 PM   #20
Gipper
CF Senior Member
St. Jude Donor '12
Gipper's Avatar
Quote:
biggest I've seen at Home Depot anyway. They'll cut it no problem.
Reload this Page What is the best way to cut a pad lock?
Tags
avoid, bolt, buy, combination, cut, cutters, cutting, hasp, lock, master, masterlock, pad, paddle, padlock, rotozip
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 11:23 AM
new letter..EARLY BIRD ORDER DISCOUNT ON 2003 MANUALS..SEP 7,02 CorvettePartsBob Ken's Newsletters 10 10-02-2002 12:44 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
