fs:99 frc pewter
fs:99 frc pewter
when I bought the car it was going to be my track day car.after owning it for alittle over 3 years I have done 4 track days and put 10,000 miles on it.i just don't have the time for track days so i'm going to sell it.
the car has 109,xxx miles and runs great.for a 99 it's in great condition.most people don't believe its that old.
car has:
ported'polished 241 heads with larger valves and comp 921 spring.they flow over 300cfm@.550
texas speed 224 114lsa cam
ls6 intake
tpis LT headers w/high flow cats and x-pipe ti exhaust
30 lb injectors
callaway honker intake
underdrive pulley
tuned by Mark Romans
poly a-arm bushings
2008 z06 shocks
front brake duct cooler
new tie rod ends
amsoil fluid everywhere
corbeau seats
harness bar with two sets of 5 point camlock harness
have new ls7 clutch with remote bleeder,slave,throughout bearing,pilot bearing(has not yet been istalled.
the only bad points of the car is the clutch will need to be changed soon and you have to hold it in reverse while you back up.all forward gears work perfect.
$12,500 no trades
car has:
ls6 intake
30 lb injectors
underdrive pulley
poly a-arm bushings
2008 z06 shocks
new tie rod ends
corbeau seats
$12,500 no trades
