Ghost's 08 C6 Z06 w/ LG Long Tube Headers, TPS Tune/Intake/ TB-503RWHP, 468RWTQ
Supporting Vendor
St. Jude Donor '11
Neeraj wanted to add little more HP and decided to take advantage of our LG Motorsports Long Tube Header Installed Promotion. For $300 we'll install any set of LG Super Pro Headers on your C5 or C6 AND Dyno Tune it Only thing you have to do is buy a new set of LG Super Pro headers from us While he was at it he decided to have us install a TPS Ported LS7 Intake and Throttle Body.
Here's our LG Motorsports Long Tube Header Install promotion
http://forums.corvetteforum.com/nort...-and-tune.html
Neeraj's new setup
-LG 1-3/4" Super Pro Headers with Cats
-TPS Ported Intake Manifold
-TPS Ported Throttle Body
-TPS Custom Dyno Tune
-NGK Spark Plugs
-160 Degree Thermostat
Neeraj's new setup
-NGK Spark Plugs
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
A heat range hotter then stock on 91 or is that a typo?
The 5 heat range is a stock replacement for an LS1/2/3 not an LS7/9.
Good package pricing though
Don't really want to argue, just stating facts. Feel free to cross reference the Delco 41-110 and 41-104 plugs against NGK and their stock applications.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
You are free to use what you like but the LS7 and LS9 cars use the same 6 heat range plug from the factory. So using a tr55 is going hotter ( and wider gap) even though it is N/A. The TR6 and 7 are often used when FI is added to an N/A car. The ZR1 is a 9:1 FI motor and the LS7 is an 11:1 N/A motor so they both use the same heat range in stock or mildly modded form. The stock replacement for an LS2/3 would be a TR5.
Nice numbers on the mods, but what were the SAE corrected numbers?
FWIW I run a Denso IT-22 on my car which is a stock compression LS3 with 10 lbs of boost. That is the equivalent to a TR7IX plug. The first post edit will help board lurkers from being mis lead on plug choice.
Supporting Vendor
St. Jude Donor '11
I actually just spoke to Aaron and he swap them out to TR6s before he installed them.
I assumed you knew what was installed since you defended it.
Is your 224x an Eddy Current model? If not that may explain how you are getting away with a 5 heat range.
