Drag Racing This Weekend At Infineon (Jan. 28-29)
It should be a great weekend for the Summit ET drags at Infineon... temps should be in the mid 60's and just perfect for those wishing to set best personal times.
Gates open both days at 7 AM with time runs set for about 8:30 or so.
This is a open event to EVERYONE
Here is the run order in case you are interested on how each class will be called into the lanes for time runs.
1. Trophy
2. Sportsman (12 seconds and up)
3. Pro ET
4. Super Pro
5 Motorcycles
This order will be repeated until the start of eliminations which should be anytime after 12:30
Track broadcast frequency is 87.9 FM and it will also be aired live with both audio and video on www.1320go.com starting at 8 AM each day.
Sunocco race gas both leaded and unleaded is available at the track
1. Trophy
3. Pro ET
4. Super Pro
5 Motorcycles
Willie,
Is the engine finished and if so, will you be making it out to the track both days?
Weather should be awesome, almost 70 degrees according to some reports and who would have thought that in the midst of Winter?
