Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Northern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Northern California Northern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2009, 08:31 PM   #1
bobmoore2
CF Senior Member
bobmoore2's Avatar
Default Is anyone going to Infineon on Nov 21st, or Buttonwillow on Nov.28th?
I need another fix for my track addiction soon.
The Dec. 4th Laguna Seca (NCRC) event is full , and I was at Thunderhill just last weekend. So I'm not interested in another T-Hill event for a month or two.
I'm thinking about going to one of the following events. I know that both organizers puts on good track day events, and both tracks are a lot of fun too. The thing that will help me decide is whether any of my friends will be there also. Are any of you going to either of these?
Nov.21st Infineon (TrackMasters)
Nov. 28th Buttonwillow (Green Flag)
__________________
YUR2SLO
'06 Velocity Yellow Coupe, Cashmere interior, Z51, 6-speed, 3LT. Bought Oct. '08
Daily driver & weekend race car.
Mods: R-comp tires, Brake ducts, accusump. More mods soon.
Previous Vettes:
'00 Torch Red convertible, Black top & interior, Z51, 6-speed, 3LT.
'87 Dark Red Met. 'vert, 4+3 shifter.
'70 Donnyebrooke Green coupe, 454/390, 4-spd, AC, PS, PB.
'89 Dark Red Met. 'vert, A/T, ZZ4 engine, 4-pt roll bar, big brakes, bigger radiator.
bobmoore2 is offline   Reply With Quote
Old 11-07-2009, 12:30 AM   #2
trackboss
CF Senior Member
Send a message via Yahoo to trackboss
I'm thinking about going to sears either the 21st or 22nd. Just got my car running. Will be weather dependent.
trackboss is offline   Reply With Quote
Old 11-07-2009, 11:00 PM   #3
bobmoore2
CF Senior Member
bobmoore2's Avatar
Quote:
I have to work on Sundays, so I can't do the 22nd (or the 29th either).
Old 11-08-2009, 09:22 AM   #4
Astrodokk
CF Senior Member
Astrodokk's Avatar
I've never done an open track event, and I was going to go to Sacramento for the test and tune. But I've drag raced all season and I've been interested in track recently (I did my first autox too), so I think I will sign up for this...and it's close to home. Thunderhill is so far. Thanks for posting this!
Astrodokk is offline   Reply With Quote
Old 11-09-2009, 12:39 PM   #5
bobmoore2
CF Senior Member
bobmoore2's Avatar
Quote:
Welcome to the next level on the Pyramid of Speed.
http://www.nsxfiles.com/Pyramid_of_speed.htm
You came to the right place. Several of the people here have been doing HPDE/track events for several years. For example, I've been doing them for over 8 years. All of us veterans started out as complete novices, and got a lot of advice from the veterans. So now we have a duty to help out the novices. We're here to answer any questions you may have, or to do anything we can to make you more comfortable as you take this big step.
Old 11-09-2009, 01:09 PM   #6
DarkMastyr
CF Senior Member
DarkMastyr's Avatar
where's the casual HPDE guy on that pyramid? I don't do TT or W2W... yet...
nm I see he lumped HPDE/TT into the same category.
DarkMastyr is offline   Reply With Quote
Old 11-09-2009, 01:28 PM   #7
bobmoore2
CF Senior Member
bobmoore2's Avatar
Quote:
I just found out last night that I will have to work on the 21st, but not the 29th. (I'm trading a work-day with a coworker.)
So my work schedule has made the decision for me. I will be going to Buttonwillow on Nov. 28th or 29th, or maybe both days.
Astrodokk, If you want to come to Buttonwillow on one or both of those days, I'll guide you through your first track day. Let me know which day(s). Sorry that Buttonwillow is so far from you, but it really is a fun track. If you want to go to Infineon instead, then someone (maybe Trackboss) will probably volunteer to guide you through your first track day there.
Old 11-10-2009, 12:09 AM   #8
Astrodokk
CF Senior Member
Astrodokk's Avatar
Thanks for the offer. I'll be in Seattle on the 28th over the Thanksgiving holiday, so I can't make Buttonwillow. I may not even make Infineon on the 21st if I find I have a problem with my engine. I bottomed out over a dip on the freeway and hit the oil pan, which knocked the pickup loose, which caused zero oil pressure. I'm going to take the pump out for inspection, and if it's cracked, I'll need to order a new one. So hopefully everything will be together and tight by the 21st. I've already registered for it but have not paid yet. Hopefully I'll see 'ya.
Carlos
The circled "bulge" used to be flat! When I dropped the pan a few minute ago, the pickup was at the bottom of the pan. I hope the pump is still good.
Old 11-10-2009, 11:04 AM   #9
StArrow68
CF Senior Member
StArrow68's Avatar
Send a message via AIM to StArrow68
DarkMastyr, HPDE and TT get lumped since many migrate from one to the other and
some groups run them together, just allowing those that want to run a timer and others
to not run a timer. Some such as NASA run a separate TT group but that is the only
regular group in Nor Cal that I know with a separate group. NCRC runs them together
in the upper groups or a special session and SpeedVentures does the same in all groups.
When you run HPDE in your first few times on track the last thing to worry about is times,
but as you progress it is really the only way to judge advancement of your skill set. And
it is a tremendous amount of fun! Most groups class based on your car and what tires
you run so any set up is ok, I never got beyond street tires, 220 wear rating, so you don't
have to go beyond that. Missing my track time, enjoy!
Randy
__________________
If you're off line, you only think you're going fast!
2002 EB/Oak Z51, w/MN6, Magnaflow & XPipe, brake ducts w/Z06 wheels & street tires for the track. 2.00.8 at Sears Point, main road course. 1.49.9 at LS, and TH 2.09's. BW 2.08.9 25CCW. Old R-F 1.34, new R-F 2.10/F, 3.11/A . SM at 1.57's, school car. 9/28/01 at Fichtner Chev.
24 June 2004, MY Coupe, 6sp, Z51, 1SB, polished wheels, Z06 screens, Z06 red brake calipers & Corsa Indy.
StArrow68 is offline   Reply With Quote
Old 11-11-2009, 12:31 PM   #10
bobmoore2
CF Senior Member
bobmoore2's Avatar
I just registered for the 28th.
Old 11-15-2009, 09:34 PM   #11
Astrodokk
CF Senior Member
Astrodokk's Avatar
Bob, good luck at Buttonwillow. I won't be making it to Infineon. My car is out of commission. Not only did the oil pickup dislodge, but the bearings fried. Gonna have to pull and teardown the engine over the winter. Any suggestions you have for a C2 that will be used for track would be appreciated. Already getting new sway bars and have the slicks.
Old 11-17-2009, 12:21 AM   #12
trackboss
CF Senior Member
So far weather looks clear for saturday so I might actually make it with trackmasters. Anyone else planning?
Old 11-18-2009, 07:19 PM   #13
Astrodokk
CF Senior Member
Astrodokk's Avatar
I may just show up to watch the action, and to see how it is organized so that I can do it next year.
Old 11-19-2009, 01:04 AM   #14
trackboss
CF Senior Member
I tried to sign up today and it was full in the advanced group. Unless they send me notice of cancellation I'm out of luck.
Old 11-19-2009, 12:46 PM   #15
Sidney004
CF Senior Member
Advanced still open for Dec. 7 with NCRC:
http://www.ncracing.org/events.php
weather is too far out to predict:
http://www.accuweather.com/us/ca/val...ler=1&metric=0
Sidney004 is offline   Reply With Quote
Old 11-19-2009, 10:23 PM   #16
trackboss
CF Senior Member
Thanks for pointing that out. Last night I looked over the schudules for t-hill, sears, and, BW to see what was left. Sears for some reason does not list the 12/7 event and I would have not known about it. If the weather is dry I'll be there.
Old 11-22-2009, 12:57 AM   #17
StArrow68
CF Senior Member
StArrow68's Avatar
Hope the day ended well for everyone. Got to take a couple rides helping
a newbie make it around the track in the morning and then bailed out on
the rest of the day. It sure was a great day to be out on Sears Point, just
a beautiful day (except for maybe the guy who had his very new P-car
delivered to one of the NASCAR garages), guess taking it home might have
just raised more questions. Ugly.
Randy
Old 11-27-2009, 01:55 AM   #18
TPSMak
Supporting Vendor
St. Jude Donor '11
TPSMak's Avatar
For anyone who's never done open tracking you have to do it.... it's is absolutely addictive!
__________________
Mike Mak
TPS Motorsports
TPSMotorsports.com
180 E. Sunnyoaks Bldg #3
Campbell, CA 95008
__________________
TPSMotorsports.com
Mike Mak
180 E. Sunnyoaks Bldg #3, Campbell, CA 95008
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Racing Seats, Edelbrock Super Chargers, A&A Superchargers, LG Motorsports, Pfadt Racing, Billy Boat Exhaust, GHL Exhaust, TPS 427 Shifter, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
TPSMak is offline   Reply With Quote
Old 11-27-2009, 01:01 PM   #19
bobmoore2
CF Senior Member
bobmoore2's Avatar
Default Getting ready to go to Buttonwillow.
Looks like we will have some light showers in the morning, followed by partly cloudy, but cool, the rest of the day.
Buttonwillow weather forecast
We won't be setting any records, but it should be a fun day anyway. It should reduce the tire and brake wear.
Reload this Page Is anyone going to Infineon on Nov 21st, or Buttonwillow on Nov.28th?
Tags
1221, 2009, buttonwillow, greenflag, infineon, lease, ncrc, pics, racecar, racing, thanksgiving, trackboss
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
