Thanks for the support guys. Wew would be happy to help you out. There is a good chance that it has nothing to do with the roof delaminating. It is more then likely the front guide pins squeeking and popping. There is a TSb out for the exact complaint and we have fixed a ton of them. Here is a copy of the TSB. Let me know if we can help you out.
RICH
#05-08-59-003E: Creak or Popping Noise from Roof Near Windshield/A Pillar (Replace Plastic Guides in Roof Striker and Add Flocking Tape and Shim Stock) - (May 9, 2007)
Subject: Creak or Popping Noise from Roof Near Windshield/"A" Pillar (Replace Plastic Guides In Roof Striker and Add Flocking Tape and Shim Stock)
Models: 2005-2007 Chevrolet Corvette
with Lift Off Roof Only
This bulletin is being revised to emphasize the replacement of the plastic guide. Please discard Corporate Bulletin Number 05-08-59-003D (Section 08 - Body and Accessories).
DO THIS
DON'T DO THIS
Replace the plastic guide.
DO NOT replace the roof handles.
Condition 1
Some customers may comment on a creak or popping noise in the roof near the windshield area.
Condition 2
Some customers may comment on a creak or popping noise in the A-pillar area.
Cause 1
The roof guide pins may have elongated the plastic guides.
Cause 2
The windshield garnish molding may be causing the noise.
Correction 1
Replace the left and right plastic guide in the roof latch striker following the procedure below. (Note that the latch is on the headliner, next to the "A" pillar.)
Unlatch and remove the roof.
With a small screw driver, unlock the four fingers of the guide from the striker and discard them.
Remove the flocking tape from the new guides.
Install a piece of flocking tape under the brim of each of the guides (8 mm [0.31 in] wide by 50 mm [2 in] long) as shown above.
Install the new plastic guides into the striker.
Install the roof.
Correction 2
Install flocking tape and shim stock to the following areas
• The A-pillar (shim stock)
• At the end of the windshield garnish molding (flocking tape)
Remove the windshield garnish. Refer to Windshield Garnish Molding Replacement in SI.
Install a piece of 2 mm (.080 in) shim stock, 40 mm long by 10 mm wide (0.31 in by 1.6 in) to the A-pillar as shown above.
Install a piece of flocking tape 8 mm wide by 40 mm long (0.31 in by 1.6 in) to the edge of the windshield garnish molding and wrap it around the back side of the molding as shown above.
Install the windshield garnish. Refer to Windshield Garnish Molding Replacement in SI.
Parts Information
Order BRS Tape and Adhesive Back Shim Stock from Kent Automotive at 1-888-YES-KENT or online at
www.kent-automotive.com.
Part Number
Description
Qty
19120702
Spacer, RF Lift Off Pnl/Wdo Frt Stkr (LH)
1
19121172
Spacer, RF Lift Off Pnl/Wdo Frt Stkr (RH)
1
KT-13485
BRS Tape
P40100
